spun bearing
Old Dec 23, 2002 | 08:49 AM
See Are X's Avatar
Default spun bearing
Im getting a good deal for an LS motor with a spun bearing. Would this be inexpensive to fix? He said the motor was still running when they pulled it out. What would I need to replace?
Old Dec 23, 2002 | 09:07 AM
CHEETAH's Avatar
Default Re: spun bearing (See Are X)
depending on the extent of the spun bearing ... if oyu need to cut the crank journals down, cant go lower than the clearance of the new rod or the bore on each main (depending which bearings spun - typically the rods spin first) vs. new cut journal or you'd have to get a new crank or get your rods or main caps milled then align-bored ...
greg
Old Dec 23, 2002 | 09:23 AM
earl's Avatar
Main or rod spun? Makes a big difference in cost to fix. Spun main and I would pass on the project.
BTW motors don't run very long if they really have a spun bearing.
jakscivic
Feb 21, 2013 08:27 AM
ziggy3784
Apr 30, 2009 07:48 AM
shaolyn
Mar 21, 2009 10:47 PM
eg4life1202
11
Jan 14, 2007 09:17 AM
nkymain
11
Sep 22, 2005 01:25 PM
