Help! My car turned into a mouse!
Old Dec 23, 2002 | 04:20 PM
youngkow's Avatar
Default Help! My car turned into a mouse!
My car is squeaking like crazy! I just installed coilovers, kyb agx, and front and rear sway bars. I made sure the bushings were well lubed. How can I tell if the tires are rubbing on the fender liners? I only dropped approximately 1 inch. Please someone help!
Old Dec 23, 2002 | 08:47 PM
youngkow's Avatar
Default Re: Help! My car turned into a mouse! (youngkow)
Pleaseeeeee! It's getting really annoying. Every time I turn all I hear is squeaky squeak squeak . Any suggestions? Thanks.
Old Dec 23, 2002 | 09:03 PM
enhancedCL9's Avatar
What kind of car you got? Are you sure it's the suspension?
Old Dec 23, 2002 | 09:28 PM
youngkow's Avatar
Default Re: Help! My car turned into a mouse! (SLOW CRX)
I have a 99 lx. Im pretty sure its the suspension because it happens every time i turn or go over a big bump.
Old Dec 23, 2002 | 10:54 PM
mugenDAxsi's Avatar
check your brake dust shields.... push'em away from the rotor and it might fix it. let me know what happens...
Old Dec 24, 2002 | 05:56 AM
youngkow's Avatar
Default Re: Help! My car turned into a mouse! (mugenDAxsi)
Thanks, I tried it last night, and it didn't work. I think its coming from the bushings from the sway bars. I have suspension techniques, and the bushings are really hard. I was just wondering if it could be the shocks that could be squeaking.
Old Dec 24, 2002 | 06:08 AM
non-VTEC's Avatar
it might be your bushings.........take them off and go for a drive and see if the sound goes away. if it does then you need to put more lube on them.
and make sure you use the proper lube/greese for polyurathane bushings. that suff works good......
Old Dec 24, 2002 | 06:25 AM
youngkow's Avatar
Default Re: Help! My car turned into a mouse! (non-VTEC)
Thanks!
Old Dec 24, 2002 | 06:31 AM
RAWB's Avatar
Alot of time, suspension components squeak as the weather gets colder-especially if your using poly urethane bushings. For me, it's something I luckily only have to deal with a few months in the year living in California. If the squeaking doesn't go away, don't fret-it most likely will when the weather warms up.
[Modified by integracon, 7:32 AM 12/24/2002]
Old Dec 24, 2002 | 07:41 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Help! My car turned into a mouse! (integracon)
Mine tokicos squeek everytime I go over this certian bump in mu neighborhood. It just how it is. I should of greese'd em!
Blaze
Old Dec 25, 2002 | 03:46 PM
delslow94's Avatar
if you kept the rubber bushing in the top hat of the shocks that might also squeek. mine does when it gets cold so i shoot up some lube in that area and it cures mine...hope it helps.
Old Dec 25, 2002 | 06:57 PM
SOHCMAN's Avatar
Default Re: Help! My car turned into a mouse! (delslow94)
*Joke: to fix it just install a cat! (sorry, a bit corny)
ya, just lube up the bushings, hope you get it to stop-way annoying!
sohc
Old Dec 25, 2002 | 09:16 PM
RAWB's Avatar
Default Re: Help! My car turned into a mouse! (SOHCMAN)
If all else fails, just turn up the radio
93 DB2
Suspension & Brakes
Nov 13, 2011 05:39 PM
gtlaw1
10
May 21, 2007 09:50 PM
idriveadelsol7
Suspension & Brakes
Aug 9, 2005 10:36 AM
nj0ywatch1np0rn
Oct 30, 2003 06:24 PM
SyndicateEH
Jan 18, 2002 12:42 PM
