Enough clutch?
Old Dec 23, 2002 | 11:53 AM
fastbrakes's Avatar
Default Enough clutch?
I've got the B18 LS/VTEC about ready to go in the car and now I'm wondering if I enough clutch. The engine has 11.2CR, Skunk Stage2 cams, Skunk2 Intake manifold, Skunk2 cams gears, SMSP adjustable length header, 62mm TB, Hondata ECU. I think it will put out close to 200 WHP by the time I'm done tuning it. I have a new ITR clutch and pressure plate I was going to put on. Is that enough or should I go to something a little heavier duty?
Old Dec 23, 2002 | 01:31 PM
Kataku2K3's Avatar
Default Re: Enough clutch? (fastbrakes)
I would atleast upgrade to an ACT HD pressure plate... It'll hold back a little more than an ITR clutch... Feel like spending some money (~$1300 drop one of these Tiltons in, hehe)
Old Dec 23, 2002 | 01:57 PM
Dual Cams's Avatar
i don't think the ITR clutch would hold up for too long. Try to look into ACT or Clutch Master.
i have a Clutch Master stage 4 brand new never been mounted onto the flywheel for $320 shipped. If you're interested hit me up.
BTW how much are those SMSP headers go for?
[Modified by Dual Cams, 6:00 PM 12/23/2002]
Old Dec 24, 2002 | 09:42 AM
fastbrakes's Avatar
Default Re: Enough clutch? (Dual Cams)
Thanks guys, I am just a little worried that if I put the swap in there with the ITR clutch that I'll be pulling out the trans and replacing the clutch in 6 months...
I see where the Exedy organinc is only $265 shipped with bearing and alignment tool from clutchcityonline.com(I think that was it).
The SMSP sells for around $850, the adjustable one is about $100 more than the standard one....I'm looking forward to some tuning with the adjustable primaries, secondaries and collector to see how much of a difference it will make.
Old Dec 24, 2002 | 11:17 PM
Dual Cams's Avatar
how long does it take to get them?
Old Dec 25, 2002 | 12:39 AM
smallttocs's Avatar
just wanted to say thats ganna be a kick *** setup post some times soon!
Old Dec 25, 2002 | 06:30 PM
Benj's Avatar
Default Re: Enough clutch? (smallttocs)
The exedy organic should do fine, or if you want something a little more extreme then the tri-puck should do.
Old Dec 26, 2002 | 03:42 AM
1bad-eg's Avatar
Default Re: Enough clutch? (Benj)
Try out a clutchmasters or act. Tilton, I think, is a little wild for your set up.
Old Dec 26, 2002 | 09:01 AM
fastbrakes's Avatar
The headers take approx 4 months to get as they are made 1 at a time...but it will be worth it.
sohc_turbo4
Transmission & Drivetrain
Mar 31, 2013 01:21 PM
Fat Chick Magnet
12
Jan 13, 2008 10:39 PM
Fat Chick Magnet
Jan 3, 2008 10:36 PM
snowblind7x
Feb 12, 2006 01:11 PM
