Funny Noise Coming from my b18c
Old Dec 22, 2002 | 10:38 AM
Burke's Avatar
Banned
Default Funny Noise Coming from my b18c
I got a JDM b18c with about 15000 miles on it and some funny noise is coming from the motor.
Symptoms -
It is a sort of whirring, squeaking sound and only makes the noise after is has been warmed up and driven for a while. at first, i would only do it when my revs woud drop, like at an idle or something. so i would rev it a touch, it would go away till the revs dropped, and then come right back. Since then it has gotten worse. Now it whirs all the time up to and through 3 grand.
Where it is coming from -
It "sounds" like it is coming from the drivers side of the motor. Almost like it is coming out of the cam gears. It almost sounds like a worn bearing noise. I listened to both sides of the cam shafts with a stethescope and seems to sound alright and i the same on both sides. I dont have p/s or ac so i know it isnt those.
Why??
I did install cam gears and the noise didnt start till afterwards. also, i bought the cam gears used and one of the 6 bolts on it stripped and currently is on. An old p/s hose moved over and some of it got worn awy by touching the timing belt. The very edge of the timing belt got a little wear and I will be replacing it within the next 2 weeks. Also the timing belt doesn't seem to hold tension on the front side of the motor very well. I tighten it and soon after it flaps a little at idle.
Overall, the motor still seems real strong, but there is just this damn noise. If anyone has any help, I would greatly appreciate it.
Thanks a lot
Burke
Old Dec 22, 2002 | 11:20 AM
Kataku2K3's Avatar
Default Re: Funny Noise Coming from my b18c (Burke)
Did you check the water pump when you changed the cam gears?? I would also check to make sure that your tensioner is tight... if it is a little loose it could cause you belt to side out towards the t-belt cover.... I would just pull the crank pulley, t-belt covers, t-belt, and water pump to check everything... If everything seems fine then just put it all back on but make sure you have everything tight and set correctly... Good Luck
Old Dec 22, 2002 | 12:51 PM
Burke's Avatar
Banned
Default Re: Funny Noise Coming from my b18c (JDMspecEG6)
No, I didnt check the water pump, but that sounds like a viable culprit. I will change it when I change the timing and alt belt. Hopefully that is all it is. I also think the spring in my tensioner is going. I'll see about changing that too. Does anyone know if you can just buy the spring or would I have to buy a whole new tensioner???
Thanks a lot
2kdrift
Mar 28, 2016 10:50 PM
Freshdot
Jun 12, 2012 01:21 PM
