Oil Leak question.....
Old Dec 20, 2002 | 07:50 PM
. o 69 o .'s Avatar
Default Oil Leak question.....
There is oil here:
Coming from here:
How do i fix this?
Old Dec 20, 2002 | 07:56 PM
RyanR's Avatar
Default Re: Oil Leak question..... (B16B)
Get a new cam seal. The cam seal is that black cap your pointing at in the second pic. About $4 from any honda dealership.
Old Dec 20, 2002 | 07:59 PM
Desslok's Avatar
Default Re: Oil Leak question..... (RyanR)
You can also get bling bling ones that have double or triple seals.
Old Dec 20, 2002 | 09:00 PM
Chiovnidca's Avatar
Default Re: Oil Leak question..... (sp)
You can also clean the old on and put some Hondabond on it.
Old Dec 20, 2002 | 09:18 PM
Kataku2K3's Avatar
Default Re: Oil Leak question..... (Chiovnidca)
Honda Bond.... The fix for everything
Old Dec 20, 2002 | 10:17 PM
. o 69 o .'s Avatar
Default Re: Oil Leak question..... (JDMspecEG6)
NooB question.... What is Honda Bond?
Old Dec 20, 2002 | 10:21 PM
D16SI's Avatar
take vavle cover off , make sure all bolts are torqued to oem sp ecs.
Kataku2K3's Avatar
It's what is used factory on most all of the oil seals... It's just expensive high temp RTV sealant... You can buy stuff that is very similar to it at most auto parts stores... Honda Bond is more expensive just because it's factory but it's what I use... I get it for $17 a tube and it normally lasts awhile for me even when using it everyday... You can see in this post we were just talkin about stupid stuff.. https://honda-tech.com/zerothread?id=361446
Old Dec 20, 2002 | 10:25 PM
D16SI's Avatar
if not that , they make a die that you put in the oil and it will show you where the leak is really coming from by using a black light its cool
Old Dec 20, 2002 | 11:33 PM
Lysawy's Avatar
Default Re: Oil Leak question..... (D16SI)
i had this thing too well just used a hi temp silicone sealent , its holding up !!!!!
Boobookitty81
Honda Civic (2001 - 2005)
Mar 27, 2017 11:32 PM
DC4_Dad
Sep 29, 2014 03:43 AM
justBrowsing
Jan 8, 2013 07:09 AM
Scrappy_jm
May 14, 2008 04:52 PM
UNDER PRESSURE
Nov 18, 2003 10:19 PM
