dist. making wierd sounds...
Old Dec 22, 2002 | 10:44 AM
See Are X's Avatar
Default dist. making wierd sounds...
my distributor is making some wierd sounds, like metal rubbing metal....anyone kknow whats wrong???
Old Dec 22, 2002 | 11:18 AM
Perfectionist's Avatar
Default Re: dist. making wierd sounds... (See Are X)
Pull the distributor cap off and check for a redish or rust colored dust. It might be your distributor bearing going out if you see the dust and hear that noise. In the worst case, the distributor shaft could seize up.
Old Dec 22, 2002 | 11:21 AM
See Are X's Avatar
Default Re: dist. making wierd sounds... (Perfectionist)
could I replace the bearing myself?
Kataku2K3's Avatar
I'm also thinking it's your bearing... It's a horrible metal on metal grinding noise huh... Replace the bearing and see what it does... Latez
EDIT: damn you got that up quick... hahaha, when i started typing this it was Perfectionist that had posted last.. Yea you can change it yourself... Just pull off the distributor and take it apart... You could take someone elses bearing because for the most part they are the same or just order from Honda...
[Modified by JDMspecEG6, 12:24 PM 12/22/2002]
Old Dec 22, 2002 | 11:39 AM
3rdGteg's Avatar
Default Re: dist. making wierd sounds... (JDMspecEG6)
or something recently more common, your screw that holds the rotor came off and causing the rotor to rattle around in the cap. just a thought. good luck!
Old Dec 22, 2002 | 01:16 PM
See Are X's Avatar
Default Re: dist. making wierd sounds... (3rdGteg)
how do I replace the bearing? is it hard?
B16CRXT
Feb 14, 2007 05:35 PM
DAcraze
Feb 5, 2006 02:14 PM
shooitzlinh
Dec 4, 2004 09:39 PM
guttedEF
Mar 28, 2003 11:58 PM
Phat Corolla
Jan 29, 2002 06:48 AM
