YS1 with Type R lsd......?
Old Dec 22, 2002 | 01:10 AM
Jdm_Rice_Monster's Avatar
Default YS1 with Type R lsd......?
I need to know if anyone has done it and if it worked out ok. I have a 92 ys1 integra ls transmission, it is the big spline cable tranny compatible with all newer integra trannys. I am wanting to know If I can put a type r lsd in it, and even the gears so that I can achieve the ratios the type r has. I dont now about the gears workin but the lsd should, any info will help, thanks.
Old Dec 22, 2002 | 01:23 AM
HOOKUPS-PRO-CRX's Avatar
Default Re: YS1 with Type R lsd......? (JdmRiceMonster)
yes it works in the ys1 tranny and only the ys1 tranny . you will need the final drive from the type-r and the 1st gear
Old Dec 23, 2002 | 12:07 AM
Default Re: YS1 with Type R lsd......? (HOOKUPS-PRO-CRX)
So in order to run a itr lsd, I need to buy itr first gear and final drive, and will the local acura mechanice be able to do this.
Old Dec 23, 2002 | 03:38 AM
Jeff C's Avatar
I found this awhile back...
https://honda-tech.com/zerothread?id=323075
[Modified by Jeff C, 7:38 AM 12/23/2002]
Old Dec 23, 2002 | 04:35 AM
1bad-eg's Avatar
Everything should bolt right up. Only 92 and up though.
Old Dec 23, 2002 | 05:28 AM
CHEETAH's Avatar
Default Re: YS1 with Type R lsd......? (1bad-eg)
no it'll also fit in the 4.4 Y1 cable trannies too ... any cable with a 4.4 it will work providing you get the GSR/Type R ring gear (the big gear with 66 teeth)
greg
Old Dec 23, 2002 | 06:01 AM
1bad-eg's Avatar
Default Re: YS1 with Type R lsd......? (CHEETAH)
cool. I guess you learn something new everyday.
EG_SINZ
Oct 4, 2010 01:49 PM
TurboB16A300Hpteg
Jul 22, 2008 05:00 AM
bracket 4 life
Feb 13, 2005 10:05 AM
shamoo
Mar 21, 2002 07:24 AM
. o 69 o .
Jan 19, 2002 11:15 PM
