5 lug question, and vtec bseries pistons in an LS?
Old Dec 25, 2002 | 09:07 PM
dfoxengr's Avatar
Default 5 lug question, and vtec bseries pistons in an LS?
In an LS (stock 81 bore) you can use other 81 bore bseries VTEC pistons? without modifications at all, am i CORRECT? what sort of gains should be expected considering compression and all? and could you use oversized CTR pistons in the same 81 bore LS?
[Modified by hybridvteceg, 9:19 PM 12/26/2002]
Old Dec 26, 2002 | 05:20 PM
dfoxengr's Avatar
Default Re: 5 lug question, and vtec bseries pistons in an LS? (hybridvteceg)
anyone know?
Old Dec 26, 2002 | 06:31 PM
dfoxengr's Avatar
techs?
Old Dec 26, 2002 | 09:16 PM
dr650's Avatar
New User
yes u can.need little bit machining on the ls rods.better use the pr3 piston.little bit lower compresion than ctr.
Old Dec 27, 2002 | 02:30 AM
simple4012's Avatar
New User
Default Re: 5 lug question, and vtec bseries pistons in an LS? (dr650)
yep/...machine the rods 1mm on each sode and and vtec piston will fit
Old Dec 27, 2002 | 10:59 AM
dfoxengr's Avatar
Default Re: 5 lug question, and vtec bseries pistons in an LS? (simple4012)
so thats making the rod 2mm total shorter?
M2nR
Jun 27, 2006 09:19 PM
tunerraceteam
Jan 2, 2006 02:38 PM
saleensolution
Mar 22, 2005 01:49 PM
Slimm-rw-
29
Apr 28, 2004 12:46 PM
teg92
Feb 11, 2002 03:52 AM
