un-sieze bolts
Old Dec 25, 2002 | 05:07 PM
92CIVICCX's Avatar
Default un-sieze bolts
what is the best penetrating stuff to unsieze locked of stif nuts and bolts? so they dont get stripped or break and i dont kill myself trying to get em off?
Old Dec 25, 2002 | 06:15 PM
cjblmr's Avatar
Default Re: un-sieze bolts (92CIVICCX)
pb blaster is good stuff and also kroils oil I believe but its kinda expensive, also the torch is your friend I like to use the torch to heat the offending bolt and bolt hole area with the torch if possible and then quench it with some pb , works very well
Old Dec 25, 2002 | 09:46 PM
mugenDAxsi's Avatar
wd40 is one of my best friends...having air tools with a 1/2 air gun is tha ****!!! breaks 99.9% of my siezed bolts off!!!! BTW, use 6 point sockets, NOT 12 point sockets and the risk of stripping bolts is greatly reduced.
[Modified by mugenDAxsi, 6:53 AM 12/26/2002]
Old Dec 25, 2002 | 10:02 PM
TEAMGENDAI's Avatar
Default Re: un-sieze bolts (mugenDAxsi)
What bolts are you refering to?? Idont like using a torch casue the bolt gets hot and fitigues and can possible break, unless you heat them then let them cool. 1/2 drive ingersall rand always works good use 6 point impact sockets if available if not use the chrome sockets buy wear eye protection. ive had a couple of socket crack and shoot small peices of metal scrap in the air. safety first!!!!
SWC
Suspension & Brakes
May 9, 2006 08:35 PM
White V6
Aug 3, 2005 08:19 AM
MI4$DC5
19
Apr 2, 2005 09:10 AM
trellix78
Jan 26, 2005 08:20 PM
Integra_Nguyen
Aug 10, 2002 06:58 PM
