Hondata vs AFC, in ALL MOTOR setup
depending on the ammount of engine work there will probably be a diffence between the two setups.
if the engine is a basic I/H/E/C and cam gears, a VAFC would be just fine.
one you start into the heavy head porting, larger injectors and high compression pistons with high RPM's hondata would be a better way to go.
we just picked up 25hp on my friends type r with only hondata. his motor is built with pistons and rods but 25hp on n/a is very good.
Hondata
My friend's CRVTEC with 12.0:1 slugs and a Portflow head with a CTR intake cam running RC 310's runs just fine on an ITR ECU and VAFC and it's never even been on the dyno... Tuned just by feel it ran a 12.62@107 in a full interior EK... Hondata is the way to go tho... It's probably going to be switched over to Hondata once we drop some Toda B's in it... Good Luck
Jun 3 cams, 12:5.1 Wiseco pistons, skunk2 valves,ported head, 68 mm TB, JG Victorx Manifold,
CAI, 4-1 DC Headers, JUN ECU, VAFC dont really think there will be too much of a gain switching over to Hondata, maybe 5-7 horses tops, I run 18 degrees timing on 93 GAS and not so much as a ping from my enigine
310 RCs, 93 sometimes 94, I doubt there is a difference between the to, thats what I mean my VAFC is very well tuned, car made 232 to wheels I dont think I will see any gains with a Hondata, thats why I ask if anyone has made the switch and seen extreme gains
Well where in my thread did I ever say they were, read it over again s-l-o-w-l-y
maybe the second time around it might sink into that concrete head of yours
REPLYING TO HONDAATWSU
[Modified by lsvtecvx, 10:34 PM 12/24/2002]
Has anybody switch from VAFC to Hondata, in a all motor setup, did you see any gains?
Maybe u should lighten up a little, and keep any comment that is not helpful to yourself. I never asked to compare the two, I asked if anyone made the switch and saw big gains.
NotUrAvgSi
Apr 19, 2004 09:35 AM
