Which compression testers to buy?
Old Dec 23, 2002 | 10:28 AM
Charlie Moua's Avatar
Default Which compression testers to buy?
are the all the same:
sears has some from $20-25
auto zone has one for $22
pepboys have one for $19.99
http://www.harborfrieght.com has them for about $24.95
http://www.snapon.com has them for...........$194.95 WTF
which will give me a accurate reading at the best price?
Old Dec 23, 2002 | 10:56 AM
Perfectionist's Avatar
Default Re: Which compression testers to buy? (Charlie Moua)
I'm happy with the auto parts store version I got for about $20something. Accuracy really doesn't have that much significance, unless you are a hardcore engine builder. What you are mainly concerned with is the range of readings from cylinder to cylinder. The small descrepencies from one tester to the next doesn't matter much.
Old Dec 23, 2002 | 11:12 AM
Default Re: Which compression testers to buy? (Perfectionist)
THANKS much bro.
no... i'm not a hardcore engine builder.
just your adverage guy trying to find out how healthy his motor is.
Old Dec 23, 2002 | 12:02 PM
You're welcome. BTW...
You probably already know this, but the test is normally performed on a warm engine with the throttle held wide open. You should pull the ECU fuse to disable the fuel and spark systems, also. Let the engine cool down before re-installing the plugs, and use some anti-sieze compound on the threads.
94_Teggy
Mar 26, 2009 05:15 PM
polishedturd
Dec 20, 2007 12:03 PM
BIG T
Nov 17, 2007 11:30 PM
Vanilla4215
Nov 7, 2002 09:46 PM
