Carrier Bering
Old Dec 20, 2002 | 06:03 PM
HeikDiesel's Avatar
Default Carrier Bering
I just put a new tranny seal on the drivers side axle and when I went to put the 3 carrier bering bolts back in, they didnt really wanna go in that well. So I put the axle back in the spindle and tired it then and all went in good except the lower right one. Any tips?
Old Dec 22, 2002 | 10:24 PM
HeikDiesel's Avatar
Default Re: Carrier Bering (PhatAcuraIntegra)
anyone?
Old Dec 22, 2002 | 10:30 PM
riceboy's Avatar
ive always had trouble getting carrier bearing bolts in easy, until today
i was putting my car back together after an engine pull, and it was time for the carrier bearing bolts
i tried from the bottom of the car like normal, and it was difficult, like normal....
so i get frustrated and go up to the top, and take my left hand and hold up the cv joint, starting with the top right (if you were looking at it out of the car) and tightend it up short of snug, where the carrier bearing coudl still have a little movement and them the bottom left bolt same way, then the bottom right, by wiggeling the carrier bearing around slightly when first tightening the bolts, made them catch threads a whole lot easier.
long story for a simple point, sorry, just got done smoking.
[Modified by riceboy, 7:30 AM 12/23/2002]
[Modified by riceboy, 7:31 AM 12/23/2002]
Old Dec 23, 2002 | 03:45 AM
b19coupe's Avatar
Default Re: Carrier Bering (riceboy)
Sounds like you are talking about the intermediate shaft, the axle like shaft between the left axle and the transmission. Try WD40 or penetrating oil on the bolt threads. Move the shaft a little to better align the holes. If the threads on the block are damaged, use a thread chaser to clean the threads up. FYI: a carrier bearing is one of two bearings that support the differential in the transmission case.
Old Dec 23, 2002 | 05:31 AM
CHEETAH's Avatar
sometimes its easier to install one axle shaft at a time as opposed to both pieces together at one time.
BTW, the carrier bearings are inside the tranny and are somethign different, i.e. they mount onto both sides of the differential.
greg
Old Dec 23, 2002 | 07:33 AM
Nameless RB26's Avatar
Default Re: Carrier Bering (CHEETAH)
greg
lol yep. Your carrier is the housing on the LSD.
This thread had me confused.
Old Dec 23, 2002 | 08:06 AM
sneakychaos's Avatar
Default Re: Carrier Bering (Nameless)
Ditto. Although I figured out what they were talkin bout before I got to it. Dont know if thats a good or bad thing.
Old Dec 23, 2002 | 11:00 AM
riceboy's Avatar
Default Re: Carrier Bering (sneakychaos)
they often just get called carrier bearings cause of old school V8 slang, kind of ,ike rear main as opposed to front main.
Old Dec 23, 2002 | 01:13 PM
HeikDiesel's Avatar
I dont have a lsd, what is that piece called then? Im sorry if I confused most of you
Old Dec 23, 2002 | 01:33 PM
Intermediate shaft.
The carrier bearings aren't specific to LSD's. They go around the differential and hold it in place.
Old Dec 24, 2002 | 02:15 PM
HeikDiesel's Avatar
okie dokie smokey
76 camaro car
Jan 22, 2015 11:08 AM
LOLO93PRELUDE
Jun 26, 2008 03:09 PM
Hondaisok
Oct 19, 2007 07:06 AM
7808
Aug 18, 2005 09:16 PM
pumafeet10
Aug 9, 2005 09:04 AM
