Measuring Coilovers
Old Dec 21, 2002 | 12:58 PM
Muckman's Avatar
Moderator in Chief
Default Measuring Coilovers
Does anybody have an ingenious way to measure each corner when adjusting your coilovers? Ive been using the finger gap method but its never accurate. Just wondering what other ppl to do get each corner the same height.
Old Dec 21, 2002 | 04:01 PM
CXHatchback's Avatar
Default Re: Measuring Coilovers (Muckman)
Count threads on the sleeve/shock body.
Old Dec 24, 2002 | 05:58 PM
Muckman's Avatar
Moderator in Chief
Default Re: Measuring Coilovers (CXHatchback)
ironically enough at the same wheel gap my ground controls sit at different heights. first thing your going to say is they are installed wrong, but ive taken it apart maybe 4 times and everything is seated firmly. maybe my coilover sleeves are not equal length.
Old Dec 24, 2002 | 06:56 PM
poo flinger
Guest
Posts: n/a
This happened to me too. I could not figure it out for the life of me. So I just lowered one side more than the other. Oh well....
Old Dec 24, 2002 | 09:59 PM
Deluzional's Avatar
Default Re: Measuring Coilovers (I cant believe this ****)
My threads are also set equally but they sit at slighty different heights. Its not because your threads are off. IMO Its because of the extra weight being put on the springs due to us bein in the driver seat all the time
Old Dec 25, 2002 | 05:41 AM
F1HONDA's Avatar
Default Re: Measuring Coilovers (Deluzional)
you can't use the thread count method to accuately set height. if more weight is on one corner than another, the ride height will already be thrown off if set at the same thread. plus, who wants to count threads all day? just measure from the bottom of each wheel edge (not tire) vertically up through the axle line to the bottom of the wheel well opening in the body.
Old Dec 25, 2002 | 12:20 PM
piscorpio's Avatar
Default Re: Measuring Coilovers (F1HONDA)
I measured from the bottom of the perch, to the end of the threads. I managed to adjust them all equally within the millimeter (I can be pretty obsessive, yes), and everything looks pretty much level and balanced out.
Before I actually did that, I would just count rotations. (I had a point on the perch marked with a paint marker.) And this actually had things pretty close to even...just not within the millimeter.
This is on APEXi WS's for a 00 coupe.
[Modified by piscorpio, 3:21 PM 12/25/2002]
Old Dec 25, 2002 | 12:25 PM
GS-Rcivic's Avatar
Default Re: Measuring Coilovers (piscorpio)
the car is heavy on one end so dont use the thread counting. measure from the rim to the wheelwell.
Old Dec 25, 2002 | 03:04 PM
acuratech's Avatar
Default Re: Measuring Coilovers (GS-Rcivic)
i unloaded all my junk out of the car(speaker box etc...), and measured from the ground to the center of the wheel well on all 4. worked pretty well
ComCool
Suspension & Brakes
Jun 7, 2006 10:13 AM
brokenojoke
Mar 13, 2006 03:35 PM
DIP_SET FoReVr
May 13, 2004 12:08 PM
py1188
May 30, 2003 08:14 AM
