Oil cooler question?
Old Dec 25, 2002 | 04:54 PM
HybriDNA's Avatar
Default Oil cooler question?
Ok i want to install a aftermarket oil cooler on my b18a/turbo setup so my question is after i get a oil cooler kit installed what do i do with the stock oil cooler (black box) thats behind the block? Please help me on this. I couldn't find answer.
Old Dec 25, 2002 | 06:48 PM
Tweakmeister's Avatar
Default Re: Oil cooler question? (10psi)
you can leave or remove the unit.
you'll probably have to remove the unit along with the spacer that fits in-between the block and oil filter to make way for the oil cooler's spacer.
hopefully that makes sense...grab a Helms.
Old Dec 25, 2002 | 07:46 PM
HybriDNA's Avatar
Default Re: Oil cooler question? (Tweakmeister)
you can leave or remove the unit. you'll probably have to remove the unit along with the spacer that fits in-between the block and oil filter to make way for the oil cooler's spacer. hopefully that makes sense...grab a Helms.
i understand. Well i bought a stock B16a1 oil cooler that is going to be sandwich'd between block and oil filter. obviously.
Then after i do that i read that i would need to tap a fitting on the block then run a hose to one of nipples on the oil cooler then run a hose from the second nipple on the oil cooler to the thermostat connecting pipe correct?
Well you said i can remove stock oil cooler on back of the b18a block (black box). But then what would i plug the hole up with?
Old Dec 25, 2002 | 09:29 PM
alright, I'm lost haha.
I need a diagram.
edit\\ okay link didn't work. Basically, grab your Helms manual and the diagrams will show you. It's way to late for me right now.
[Modified by Tweakmeister, 1:30 AM 12/26/2002]
Old Dec 26, 2002 | 05:38 PM
HybriDNA's Avatar
someone help me please
Old Dec 26, 2002 | 09:22 PM
dr650's Avatar
New User
the black box between the trany and oil filter is not oil cooler.oil cooler is in the oil filter.(between the block and filter.there is 2 fittings that should be conected to the black coolant pipe above the filter.if u using b18 block u have to change it w/the b16 coolant pipe.
Old Dec 27, 2002 | 12:08 AM
HybriDNA's Avatar
Default Re: Oil cooler question? (dr650)
Ok i understand. But don't i have to tap a fitting to the block where the coolant passage is too?
Old Dec 27, 2002 | 07:12 PM
dr650's Avatar
New User
NO <<< just used the b16 coolant pipe ,that goes to the waterpump and thermostat<>><>>>>
97CWITR
Mar 19, 2011 07:27 AM
booboo782
Sep 23, 2010 06:30 AM
JDMTurboCivic11
Oct 26, 2004 07:18 AM
jdmcx
Apr 7, 2004 06:38 AM
