Indexing spark plugs
Old Dec 23, 2002 | 06:53 PM
lsvtecvx's Avatar
Default Indexing spark plugs
has anybody done this and also how do you keep the plug it the exact spot,do you leave it loose?
Old Dec 23, 2002 | 09:05 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Indexing spark plugs (lsvtecvx)
i never heard anyone do that in Honda world
back in the day i did that with my zcars. you use various thinkness washers to level the plug in the chamber. use high quality washers and i *think* lock washers. it was a while ago.
good thing you reminded me, i'll make to sure to do that in my new A6
stan
Old Dec 23, 2002 | 09:09 PM
RyanR's Avatar
Default Re: Indexing spark plugs (90crxsi)
I've been told indexing the plugs on a honda will do little if anything since the plug is in the center of the chamber.
Old Dec 23, 2002 | 09:33 PM
tSuperbike69's Avatar
Default Re: Indexing spark plugs (RyanR)
Indexing plugs is best for v engines. In any 4 cyl. it will not help. plus combustion design of hondas support good flame travel already.
Old Dec 23, 2002 | 11:53 PM
kinesistech's Avatar
Default Re: Indexing spark plugs (tSuperbike69)
The number of cylinders has nothing to do with it. Its all about combustion chamber desing. On 4 valve heads with a pentroof chamber there is less need for it.
Old Dec 24, 2002 | 02:52 AM
Mista Bone's Avatar
D Tranny Guru
you know why? Larry/TOO stated the facts.......
Basically, Alum rods in a high winding Pro Stock motor would "touch" the electrodes and close the spark gap, killing that cylinder.
Old Dec 24, 2002 | 05:47 AM
Desslok's Avatar
Default Re: Indexing spark plugs (Mista Bone)
Better off side gapping them.
Old Dec 24, 2002 | 09:30 AM
Chiovnidca's Avatar
Default Re: Indexing spark plugs (sp)
There is one model Honda manufactures that have the spark plugs indexed from the factory. Can anyone guess which model it is?
Old Dec 24, 2002 | 10:36 AM
lsvtecvx's Avatar
Default Re: Indexing spark plugs (Chiovnidca)
Side gapping?
Old Dec 24, 2002 | 02:40 PM
7PSI CRX's Avatar
ITR would be my first guess.
NSX? My second.
Tell me!
Tell me!
Tell me!
Old Dec 24, 2002 | 02:59 PM
Chiovnidca's Avatar
Default Re: Indexing spark plugs (7PSI CRX)
NSX? My second.
Tell me!
Tell me!
Tell me!
Nope, it's not an Acura, it's a Honda. Try again.
Old Dec 24, 2002 | 03:51 PM
Nos4R2's Avatar
S2000?
[Modified by Nos4R2, 7:52 PM 12/24/2002]
Old Dec 24, 2002 | 04:33 PM
Chiovnidca's Avatar
Default Re: Indexing spark plugs (Nos4R2)
S2000?
Nope. It's the Insight. Indexing the spark plugs was just one thing they did to improve fuel efficiency.
Old Feb 6, 2003 | 07:32 AM
Tweakmeister's Avatar
bump for more thoughts on this.
Old May 23, 2003 | 06:07 PM
Mover's Avatar
Default Re: Indexing spark plugs (Tweakmeister)
back from the dead... anyone else ?
Old May 25, 2003 | 12:36 PM
Default Re: Indexing spark plugs (Mover)
since posting about this the general concensus is...it's not needed.
the mix should "mix" quite well in the combustion chamber and evenly ignite regardless of the plug's location.
Old May 25, 2003 | 10:26 PM
earl's Avatar
4 valve pent roof chambers make indexing useless.
Old May 26, 2003 | 05:13 AM
Mover's Avatar
Default Re: Indexing spark plugs (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">4 valve pent roof chambers make indexing useless.</TD></TR></TABLE>
Makes sense... I was wondering whether anyone messed around with it while on a dyno anyway.
Old May 27, 2003 | 10:16 AM
although, and this is just something i always heard from the Zcar crowd, indexing plugs effectively moves the plug out of the chamber, removing any potential sharp edges and protruding metal, that can cause detonation.
My Zcar was boosted and i did that when we built the engine.
Stan
tropicola
Honda Fit
Sep 26, 2012 10:04 PM
katzenjammer84
Honda Civic (2001 - 2005)
Jul 8, 2009 07:55 PM
Calean007
May 9, 2005 07:04 PM
mattmw88
Feb 22, 2002 07:54 AM
JDM R98
Jul 31, 2001 07:23 PM
