difference between limited edition and regular????
Old Dec 24, 2002 | 08:25 PM
XxCarChickxX's Avatar
Default difference between limited edition and regular????
what is the difference between the ground control asjustable springs and the ground control adjustable springs limited edition??? i saw them on modacar and im not sure which to get to get for my boyfriend, but the limited edition is cheaper it says.
Old Dec 24, 2002 | 10:15 PM
ill phil's Avatar
Default Re: difference between limited edition and regular???? (XxIntegraGurliexX)
One of the main differences is that the spring rates are lower (softer) on the Limited Edition GC's. The regular spring rates can be changed to your preference with out and extra charge when purchasing, where as the Limited Edition rates are set. I believe everything else is pretty much the same on both, if you want to give Ground Control a call- they were really helpful when I purchased mine.
Just a little FYI- Lim. Ed. ones run for what - $289 or so plus shipping? I got my GC's with custom spring rates (pretty stiff) for $325 shipped from
GroupBuyCenter and damn I need to find a g/f that buys nice **** like that for my car
Old Dec 24, 2002 | 10:51 PM
Default Re: difference between limited edition and regular???? (ill phil)
is it true that if u have tokico shocks u cant use the limited edition ones? i just need to make sure they will fit my b/f's car and that they are good.
Old Dec 24, 2002 | 11:34 PM
ill phil's Avatar
Can't tell ya off the top of my head, sorry. Best bet would be to check out all the sites you can with info or (I strongly suggest) giving Ground Control a call, which may mean after x-mas.
dcsports
Suspension & Brakes
11
Dec 31, 2016 08:57 AM
EK k kay
Suspension & Brakes
Mar 13, 2006 09:39 AM
KillaB-
Dec 25, 2004 07:43 AM
743power
Mar 20, 2002 07:25 PM
