D16-v-tec Running to rich (Help!)
Old Dec 22, 2002 | 01:14 PM
tbisme's Avatar
Default -v-tec Running to rich (Help!)
I have a civic-si and installed a new cold air intake and cat-back exaust . Still passes emissions (barely), bought car new, never had rich problems. Now excessive black bumber syndrome and lost 40-50 miles per tank of gas. I think it is too much fuel - what about you? Any remedies?
[Modified by tbisme, 12:51 AM 12/24/2002]
Old Dec 22, 2002 | 05:52 PM
No-Gi's Avatar
Default Re: D16-v-tec Running to rich (tbisme)
I say buy a FPR and put the car on the dyno. Make sure you use get an A/F reading so you can tune it up.
Old Dec 22, 2002 | 06:04 PM
95siHaTcH's Avatar
Default Re: D16-v-tec Running to rich (3 South)
mine did the same thing, basicly the way it works is that you gave it more air, and made the gasses get expent more efficiently, so, your motor is compensating for the additional air and is giving it more fuel, it's not really a problem.
Old Dec 23, 2002 | 02:27 PM
tbisme's Avatar
If you decrease rail pressure will the injector atomize properly? And what kind of instrument do you need to achieve air fuel readings and do most wheel dyno places have them? Decreasing fuel pressure - I was thinking along those lines.
[Modified by tbisme, 11:48 PM 12/23/2002]
Old Dec 23, 2002 | 02:50 PM
tbisme's Avatar
Default Re: D16-v-tec Running to rich (95siHaTcH)
Don't you think leaning it out will make it run more effeciently, more power, etc. ?
I do know lean is mean...
Old Dec 24, 2002 | 12:36 PM
tbisme's Avatar
Default Re: -v-tec Running to rich (tbisme)
does anyone know what the safe range is ? ( reading on a digital a/f gauge) this one shows voltage from sensor. now im trying to lower the injector pressure W/a man. pressure reg..... hope to get a few 10ths
Old Dec 26, 2002 | 06:01 PM
95siHaTcH's Avatar
by decreasing fuel press, you will be loosing power, how would u gain power by taking away fuel? you need fuel to make power, you guys just make no sence
Old Dec 26, 2002 | 06:33 PM
TEAMGENDAI's Avatar
Default Re: -v-tec Running to rich (95siHaTcH)
First question is you check engine light on??
Old Dec 26, 2002 | 09:13 PM
dr650's Avatar
New User
check ur o2 sensor.
Old Dec 27, 2002 | 12:49 AM
Benj's Avatar
Default Re: -v-tec Running to rich (dr650)
Can adjusting/tuning cam gears with the use of a dyno actually cure the running rich problem? My b16a's running rich and that's what the mechanic told me.
Old Jan 2, 2003 | 03:08 PM
tbisme's Avatar
Default Re: -v-tec Running to rich (Benj)
benj, ajusting your cam could make a differance,but first try upgradeing your ignition system coil, cap, plugwires, plugs . This will help the fuel burn, then if you want to buy a ignition box you will have enough spark to light vegas. but in anwsor to your question, yes it could help but it may not cure it .
Im trying to stay close to my baceline without changing everything , tuning is just that .
Old Jan 2, 2003 | 03:36 PM
tbisme's Avatar
[QUOTE]If you decrease rail pressure will the injector atomize properly?
what psi. is to low ? before having to move to a chip or apex controler to back off on my fuel,what about changing my inlectors ? are the ones in a d16z6 the smallest stock ones?
[Modified by tbisme, 12:48 AM 1/3/2003]
Old Jan 2, 2003 | 06:14 PM
Benj's Avatar
tbisme, my mechanic says that the cam timing needs to be advanced to cure my particular running rich case. my ignition system is all stock, im gonna be changing plugs, might as well change the wires. af ratio on the dynojet is at an almost consistent 12. my cold idle's also fucked up (they say because of running rich), when the engine's cold and i drive the car, stepping on the clutch while in gear will cause the rpm to drop really low, oftentimes stalling the engine. someone told me it's because the engine is running rich and it can't properly burn all the fuel yet when it's cold.
jiggatone
Jan 15, 2008 10:28 PM
kaj
Jan 21, 2006 12:07 PM
Benjithx
Jan 13, 2005 10:08 AM
TURBOED-TEG
Jun 26, 2002 02:01 PM
98CivicDX
Feb 17, 2002 12:40 AM
