ctr pistons in a ls... HELP
Old May 30, 2003 | 12:46 PM
teamrushhatch's Avatar
Default ctr pistons in a ls... HELP
Will the high compression of these pistons be detrimental to the block... ie. will i easily blow something. And will i have to bore the block to get these pistons into my block?
Modified by teamrushhatch at 12:12 AM 6/1/2003
Old May 30, 2003 | 01:08 PM
martini's Avatar
Default Re: ctr pistons in a ls... HELP (teamrushhatch)
certainly not. You'll probably need to run premium pump gas. and you'll need to machine your LS rods to fit the PCTs, but other than that, you'd be good.
Old May 31, 2003 | 09:45 AM
Default Re: ctr pistons in a ls... HELP (martini)
is there no one else that knows anything about this?
Old May 31, 2003 | 11:31 AM
sgT's Avatar
sgT
machine the piston and not the rod.
what is it you want toknow?
Old May 31, 2003 | 11:59 AM
arw321's Avatar
Default Re: ctr pistons in a ls... HELP (sgT)
Seriously, you should be a bit more specific!
My advice:
Machine rod for piston.
Use ARP rod bolts.
Shot peen rods.
Not that difficult!
Old May 31, 2003 | 03:14 PM
Default Re: ctr pistons in a ls... HELP (arw321)
is that specific enough?
Old Jun 1, 2003 | 03:08 AM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamrushhatch &raquo;</TD></TR><TR><TD CLASS="quote">Will the high compression of these pistons be detrimental to the block... ie. will i easily blow something. And will i have to bore the block to get these pistons into my block?
Modified by teamrushhatch at 12:12 AM 6/1/2003</TD></TR></TABLE>
better.
yes if you arent careful and dont have the proper tuning, you can blow it real easy.
you will need machine work regardless, hone for stock bore or bore and hone for oversize pistons.
Mex_cd5
Mar 18, 2014 05:13 PM
TRAN
Dec 1, 2004 11:09 PM
TRAN
Aug 19, 2004 08:07 AM
TRAN
Apr 2, 2004 04:24 AM
Triple T
Jan 28, 2003 09:31 AM
