ECU Question
Old May 30, 2003 | 10:38 AM
Kevin Cliff's Avatar
Default ECU Question
I need to find out if a 2000 GSR Computer will plug into a 2000 si wire harness
Old May 30, 2003 | 11:29 AM
preluder's Avatar
Default Re: ECU Question (Kevin Cliff)
i dont know anyone can help this guy?
Old May 30, 2003 | 01:16 PM
turbo*s2k's Avatar
Yes it will fit, but why would you use a GSR ecu on a Si? Unless you are using a different motor!
Old May 30, 2003 | 01:22 PM
dfoxengr's Avatar
Default Re: ECU Question (TurboChrgd_Civic)
itll work.
Old May 30, 2003 | 03:13 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kevin Cliff &raquo;</TD></TR><TR><TD CLASS="quote">I need to find out if a 2000 GSR Computer will plug into a 2000 si wire harness</TD></TR></TABLE>
All 99-00 integra and civic 99-00 ecu's are compatible with each other. the problem is when using a 99-00 integra ecu in a civic is the immobilzer, it needs to be removed in order for it to power your engine & make the car start. Hit me up if you need this service
Old May 31, 2003 | 11:53 AM
turbo*s2k's Avatar
Default Re: ECU Question (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
All 99-00 integra and civic 99-00 ecu's are compatible with each other. the problem is when using a 99-00 integra ecu in a civic is the immobilzer, it needs to be removed in order for it to power your engine & make the car start. Hit me up if you need this service </TD></TR></TABLE>
Hey Katman...What's the immobilzer? What does it look like, and where is it located? Thanks!
civicek00
Oct 11, 2005 01:30 PM
jdmekB18C
Northern California (Sales)
Sep 22, 2005 09:39 PM
BLKCivicPorscheStyle*
Aug 22, 2005 12:46 PM
Gump
10
Jan 22, 2004 09:24 AM
