Turbo B20 or B18?
Old May 29, 2003 | 09:12 PM
sOLLEx's Avatar
Default Turbo B20 or B18?
I have been hearing and reading that the b20's cylinder sleeves are weaker than any other but with a low compression of say 9.0:1 and boost of say 15 psi max, am I still looking at possibly cracking the sleeves on the b20? I have both a stock b18b and b20b and am wondering which will be be better to boost. It's going into a 93 del Sol S with ultimate goal of low 12 second 1/4. I plan on boosting only, no VTEC for me so my compression should stay low. I am leaning towards the b20 because of the extra torque. It would still be more expensive to stroke the b18 to a 2.0 keeping the sleeves stock than it would to just sleeve the b20. Any input?
THX,
JustinG
Old May 29, 2003 | 11:42 PM
iwishiwereajap's Avatar
Default Re: Turbo B20 or B18? (JustinG)
if your so worried about cracking a sleeve while boosting you should just save yourself the worry and resleeve one of those bad boys. Turbos and a 12 sec 1/4 mile are serious stuff
Old May 29, 2003 | 11:43 PM
Old May 30, 2003 | 01:14 AM
FFormula1's Avatar
Sell both motors, buy a GSR swap and have the block sleeved for 84mm pistons.
Old May 30, 2003 | 02:56 AM
Westrock2000's Avatar
Default Re: Turbo B20 or B18? (Muffin')
<FONT SIZE="4">or</FONT>, you can set your goals on a Dart block which will hold more than anything you will probably ever through at it.
$2000 at http://www.summitracing.com, iron ductile sleeves boreable to ~85/86mm....upgraded everything. Just carry all the parts over from either engine and your ready.
zeusdavis
Feb 12, 2011 09:27 PM
flipldls
Jun 14, 2010 08:14 PM
mysterysktr7
Apr 23, 2009 07:51 PM
1jdmdc2
Jun 5, 2006 01:02 PM
D3LSLO
Aug 24, 2003 09:05 AM
