safe to reuse mugen headgasket?
I am going to have to replace the valve seals on my rebuilt B16, it was the machine shops fault so they will do the seals if i bring in the head...
the motor only has like 2000 easy miles on it, can i use the mugen head gasket again with the stock head bolts that were also replaced with the rebuild.
maybe just give it another spray with some copper spray TIA
I will never reuse a headgasket but that's just me... Chances are you'll be able to get it to seal again with the use of copper spray as hybridvteceg stated but that's no me... Other people on here such as TimoneX have reused their headgaskets numerous times and save ~$60 a time but oh well... I just only like using new stuff... I don't care if you ruined a headgasket to clay a motor and never even ran it, I still won't do it... It's really all up to you... Latez
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg »</TD></TR><TR><TD CLASS="quote">copper spray it too, if u reuse it</TD></TR></TABLE>
i did spray the top when i installed it the first time will it matter if i spray more copper on the old copper?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 »</TD></TR><TR><TD CLASS="quote">I would use brake cleaner or aircraft paint stripper to take off the old spray, clean off any excess residue then re-copper spray both sides of the gasket... Peace</TD></TR></TABLE>
I know the head gasket is metal... but will brake cleaner and aircraft stripper be safe to use on it?
I don't know if the aircraft paint stripper contains anything that would hurt it... BUT, I always atleast break clean (even brand new headgaskets) to rid them of any grease, dust, etc... Never had a problem with sealing after that... So I'm sure it's fine... Good Luck and if I'm ever wrong be sure to let me know, hehe... Peace
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alex_b »</TD></TR><TR><TD CLASS="quote">there's the right way, and there's the cheap way.
which one makes more sense to you?</TD></TR></TABLE>
but when i have no cash i guess the latter of the two is only possible
if your careful and do everything to spec and mae sure that bitchis nice and clean there is a good chance you can get away with it......
choices...
1 buy a new one....
2 try re-using if it works your gold.
if it doesn't you buy a new one and say **** atleast i tried...
choices...
1 buy a new one....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MisterB »</TD></TR><TR><TD CLASS="quote">i am going to just try and clean up the old one and reuse it...
worse case ill just have to replace it with a new one</TD></TR></TABLE>
hah, ok but you're just contradicting yourself. i guess i just don't see why you wouldn't bite the bullet and just buy the new one to begin with and absolve any problems that might come up. not trying to flame you, just having a hard time seeing your point of view.
Well the gasket is only like one month old and i dont feel like throwing another $120 away unless i have to... My point of view, is to save money
</TD></TR></TABLE>Well the gasket is only like one month old and i dont feel like throwing another $120 away unless i have to... My point of view, is to save money
