Just installed distributor now engine misfires and bogs need help!!!!
Old May 29, 2003 | 11:36 AM
DC2 12's Avatar
Default Just installed distributor now engine misfires and bogs need help!!!!
I just install a 98 gsr obd2 dist. in my b16 obd1 motor. My problem is now that its installed my cars has a hard time starting up. when its starts it runs a bit then it stalls. the motors in the engine bay is shaking irractly. does ne one have a answer or had this problem before. sounds like it is misfiring , the car was running fine until my distributor went out. and yes the spark plug wires are plugged in correctly .
any help would be appreciated
thanks
Old May 29, 2003 | 11:55 AM
EFb18b's Avatar
Default Re: Just installed distributor now engine misfires and bogs need help!!!! (hoacun)
Check to make sure the gsr distributor and b16a distributor fire in the same pattern and no I don't care that the wires were put in the same place. Next check your timing. Another thing: putting an obd2 distributor on an obd1 motor just doesn't sound right, but then again I could be wrong
Angeljavier3577
Apr 30, 2018 01:41 PM
adictionbass
Dec 1, 2004 02:01 PM
hybridEj6
Aug 12, 2003 07:35 PM
DC2 12
May 29, 2003 01:18 PM
CHONCH
Jul 20, 2002 07:05 PM
