aem fuel pressure regulator leaking!
installed the aem fpr. it leaks from between the fpr and banjo fitting.
was there a washer or something that aem should have supplied?
if so what would it look like?
metal? rubber? size? etc.
thanks in advance.
thanks in advance.
Are you talking about it's leaking between the fuel rail and the FPR?
The fuel filter uses a banjo fitting. The FPR uses a rubber o-ring to seal. You can use the one out of the stock FPR.
Sonny
Sonny
i got the leak pretty much taken care of. 2 new copper washers. however, there's still a slight leak. not as bad as before though.
maybe i'm a ***** and can't tighten it enough lol.
DA TeG 90
Jan 27, 2010 03:10 PM
