got water in my motor....
like it says, my motor got water...... i just got this engine it was give to me by a good friend of mine, th motor was sitting in a basement , unde the stairs for a good 3 months, but now we put it in, and when i go to check the spark plus , piston # 1 is dry, but the rest are wet...... My question is, should i drain the oil, then flush and hope that the water that comes out, i guess if theres water i could use a new head gasket right? and then try to start it with new wires and spark plugs? tel l me what do u guys think.... i tries searching, theres in't much of anything coming up..... Im so depressed....
**** just never works out..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHFREEK »</TD></TR><TR><TD CLASS="quote">... the motor was sitting in a basement , unde the stairs for a good 3 months...</TD></TR></TABLE>
Is it just water from storage or coolant that is now leaking into the cylinders? Have you actually started the engine yet?
I guess I'd leave the spark plugs out, crank it for a while to circulate the oil. That'll also polish up some parts that haven't moved in, um, 3 months... Change the oil & filter then crank some more. Measure compression or leakdown (or both) & see what that looks like.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake »</TD></TR><TR><TD CLASS="quote">
I DUNNO, THERE WAS WATER INSIDE THE SPARK PLUGS, WHEN I PULLED OUT THE SPARK PLUGS, THE WATER OBVIOUSLY WENT INSIDE THE ENGINE... I GUES ONE OF THE RESONS FOR THE MOTOR NOT TO START WAS BECAUSE OF THE WATER IN THE SPARK PLUGS... WHAT DO I DO? I HAVE TO CALM DOWN DAMN IT!
So there was just water in the plug wells but not in the motor.
Step away from your monitor and go outside and play. When you return, pick up a new set of plugs, oil, coolant etc to flush out those old fluids, take all the plugs out, crank the motor over to get the water out then put new plugs in and start it.
Good news, i drained out the oil, added new oil, added new spark plugs, and viola... she turne right on.... thanks guys!
does it ever happen to you guys that when some **** goes wrong you jusrt want to give up... i even went to the extreme and thought of putting my stock engine back on and selling the hach. I dont know i guess its just my nature to be to desperate..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHFREEK »</TD></TR><TR><TD CLASS="quote">does it ever happen to you guys that when some **** goes wrong you jusrt want to give up... i even went to the extreme and thought of putting my stock engine back on and selling the hach. I dont know i guess its just my nature to be to desperate..</TD></TR></TABLE>
How about you take some valium, relax, and do some research before you jump to conclusions?
Anyways, glad everything worked out, no one likes busted motors -
