overheating
Old May 29, 2003 | 10:41 AM
af97civic's Avatar
Default overheating
for some reason my car keeps overheating when i get to 60-85 mph.its not my thermostate(replaced) and my fluid level is good.far as i know my water pump is still good.i have no idea what it could be.if you could steer my in the right direction it will be appreciated.peace
Old May 29, 2003 | 11:37 AM
BeerMan's Avatar
Default Re: overheating (af97civic)
Did you install your thermostat correctly? I remember one post a little while ago where the guy put the thermostat in backwards.
Old May 29, 2003 | 12:32 PM
1bad-eg's Avatar
Default Re: overheating (BeerMan)
Also check your fans and see if they're coming on. If they're not working, your car could overheat.
Old May 29, 2003 | 01:09 PM
af97civic's Avatar
i haven't put the new thermostat in and my fans come on when it gets hot.so its either a air bubble in the system, ablown head gasket,or bad water pump.but i don't think its a blown head gasket because it won't overheat at idle,it overheats when im going around 60 80 mph. and as far as i know my water pump is working.do you think it may be a bad radiator cap? i need help thanks
Old May 29, 2003 | 01:11 PM
Raz1983's Avatar
Default Re: overheating (1bad-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bad-eg &raquo;</TD></TR><TR><TD CLASS="quote">Also check your fans and see if they're coming on. If they're not working, your car could overheat.</TD></TR></TABLE>
Thats only at low speeds, at high speeds it shouldnt matter
im guessing upside down thermostat as well. check the level of your rad too. you can do a pressure test, but youd have to go down to a shop (im guessing a privater doesnt have a pressure tester).
Old May 29, 2003 | 01:13 PM
poison's Avatar
Default Re: overheating (Raz1983)
do a complete flush of the system, and make absolute sure there is no air inside the water system.
also make sure the thermostat is installed correctly, and the gasket is sealed properly as well.
hollums2k
Aug 25, 2021 05:00 PM
Tunedwhitey
Honda CR-V & Element
Jun 26, 2018 11:59 PM
EChangApe
May 5, 2009 10:11 AM
draperj09
Oct 22, 2007 03:37 AM
john457
Jun 1, 2007 10:26 PM
