tranny for turbo setup?
Old May 30, 2003 | 03:29 AM
90teg's Avatar
Default tranny for turbo setup?
i know i need a knew clutch and i was going get an LSD, but when going turbo is there anything else to factor in on the tranny?
Old May 30, 2003 | 06:54 AM
Spade's Avatar
Default Re: tranny for turbo setup? (90teg)
Light flywheel, shorter gears, strong clutch, and a LSD.
Shorter gears = always in boost.
Old May 30, 2003 | 08:34 AM
EFSiR's Avatar
Default Re: tranny for turbo setup? (Spade)
I'd go with LS trany and Quafie (SPP???) LSD. ITR may not hold....
Old May 30, 2003 | 12:48 PM
Blaze45's Avatar
Brrraaaap!
Default Re: tranny for turbo setup? (EFSiR)
Ive herd that some trannies can take over 500hp.... The only thing not stock is the clutch....
Blaze
Old Jun 2, 2003 | 04:44 AM
90teg's Avatar
Default Re: tranny for turbo setup? (Blaze45)
thanks for the help.....
Old Jun 2, 2003 | 07:09 AM
Kataku2K3's Avatar
Don't run an LS tranny unless you have a straight LS motor, we won't even run them on our 500whp+ turbo cars because the gears are just too long... You have two real options that work well if you have a B series VTEC motor... Either a straight GSR Y80/S80 with Quaife LSD or you can completely hybridize an LS, using the same LSD... If you've seen any of the vids that I have up on H-T you can see Duc's car, during break in we ran an LS tranny (with Quaife LSD) on it for sake of just being able to drive normal... It's hard to cruise on the freeway at under 3000rpm with anything shorter ie GSR/ITR/B16 gearing... Tuned at only WOT with like a T04X^2 turbo it made 489whp... (With the new turbo we want 600-650whp) Anyways on 18" Volk TE37's it can just barely break loose 3rd on the freeway... Brian's B18C1 making 501whp now (21lbs of boost) can break loose 4th and 5th!!! He's running a GSR with Quaife LSD tho... Here's the video if you never saw it... (Right Click and Save Target As) Ground Zero Motorsports Video Have Fun!!!!
Old Jun 2, 2003 | 07:24 AM
SupaTeg's Avatar
Default Re: tranny for turbo setup? (Kataku2K3)
Is breaking loose a good thing?....maybe it is just me but I thought you would want traction
Old Jun 2, 2003 | 11:59 AM
Kataku2K3's Avatar
Default Re: tranny for turbo setup? (SupaTeg)
Track ='s MT 24.5x9x13 slicks... We grip going into third with them... Probably try some 26's soon... Try what you want but I'll tell you, I don't think you'll like the straight LS if you compared it to a GSR... Latez
Old Jun 2, 2003 | 02:36 PM
90teg's Avatar
i don't have a vtec motor. i'm boosting my LS so you saying the b18c1 w/ the Quaife is the way to go??
buttsneeze
Sep 9, 2004 01:29 PM
buttsneeze
Sep 2, 2004 06:58 PM
Mr.DC2TurBo
Aug 30, 2004 05:35 PM
precord96
Oct 27, 2003 04:25 PM
Sukebei Oni
Apr 16, 2003 05:54 PM
