sohc arp headstud issue
Old May 28, 2003 | 03:30 AM
turbodsmpower's Avatar
Default sohc arp headstud issue
Ok ive got a buddy of mines w/ a sohc vtec engine just got done out of the machine shop. Now the bottome end is a 98 d16y8 and the head is d16z6. We are in the process of putting the headstuds on but when we put the head on the threads stick out above the head about 1/4 to 1/2 in so even if you try to snug them down the actualy nuts wont touch the head. Any suggestions its like the studs are too long.
Old May 28, 2003 | 04:10 AM
D-Man's Avatar
Default Re: sohc arp headstud issue (turbodsmpower)
I did the reverse,I put a D16Y head on D16Z block,only two studs where longer.The outer ones on the intake side.After dealing with arp,they said my only and best option was to put arp washers under the studs in question.I ended up using 3 in total on one and 2 on the other......I think ARP just came out with a new set for the D16Y but im not sure......you gotta call them
ps.........how many studs are too long? it should only be 2,right?
Old May 28, 2003 | 04:15 AM
Charlie Moua's Avatar
Default Re: sohc arp headstud issue (D-Man)
Damn thats messed up!
I would think that APR would atcully have done some research. But is it only with the D16 head bolts? I haven't heard anything bad about the B-series bolts.
Old May 28, 2003 | 05:34 AM
Default Re: sohc arp headstud issue (Charlie Moua)
apparently they have one set they said for all dseries is what they said do they even offer for the d16y8 head studs ?
Old May 28, 2003 | 07:03 AM
D-Man's Avatar
yup...its sad.You know what also sucks.They highly recommended NOT to try and thread the studs the rest of the way down AND they won't even bother making one custom length ones even if you wanted to pay $$$ for them
PhrequenC
Jun 9, 2008 10:55 AM
1FSTNDN
Jun 22, 2005 07:24 AM
9seccivicsi
Sep 20, 2004 10:55 AM
TurboSedan
May 3, 2004 02:36 PM
baonest1
Oct 17, 2002 06:29 PM
