chattery clutch
Old May 28, 2003 | 07:16 PM
neilff's Avatar
Default chattery clutch
my clutch chatters a bunch
and i can only get out of first smooth if i ride it
is there a way to fix this problem?
it grips okay, but i mean, if i try not to ride it
it jerks all over the place
and i cant engage it easily with low revs,
i have to rev it up high, let it drop and pull it out
to get it to go smooth
so in the end, i find myself driving extremely
fast out of 1st cause its not possible anyways else..
im gonna kill myself if i dont get it fixed
Old May 29, 2003 | 07:26 AM
neilff's Avatar
Default Re: chattery clutch (neilff)
upp
Old May 29, 2003 | 08:24 PM
neilff's Avatar
uppppppppp
Old May 29, 2003 | 09:22 PM
Luke J's Avatar
Is your throw-out bearing making a grinding noise?
How old is your clutch?
Old May 30, 2003 | 07:25 AM
neilff's Avatar
Default Re: chattery clutch (Lucky925l)
im not sure how old it is
ive had the car since jan. '03
and it had been doing it ever since
i havent checked over anything yet
there is no grinding noise
Old May 30, 2003 | 07:27 AM
.RJ's Avatar
.RJ
time for a new clutch, i think
Old May 30, 2003 | 08:02 AM
1bad-eg's Avatar
The chatter comes from hotspots on the flywheel. Time to replace the clutch.
Old May 30, 2003 | 08:41 AM
tilt's Avatar
I had the same symptom when a metal bracket broke off the clutch disc plate. the car would shudder trying to engage in 1st gear unless i revved high and let off the clutch pedal slowly, and it would be difficult to put into gear sometimes (synchros grinding) and have sporadic clutch chattering.
Old May 30, 2003 | 11:34 AM
preluder's Avatar
Default Re: chattery clutch (tilt)
yup so its synchronizers,flywheel maybe, new cluctch and throwout bearin i should know mine was fucked it was a bitch tryin to change gears. And there was a wiring noise booger shop sucks major **** dont go there having problems till this very day.
s_vares
Acura TL, RL & ZDX
Jul 16, 2011 04:40 AM
Jmumblez2001
Aug 8, 2006 12:05 PM
fanatic
Apr 13, 2005 06:26 PM
m3dia_lab
10
Nov 11, 2004 06:25 PM
ToneyTigre
Jan 14, 2002 04:47 PM
