Is this the cover to get access to the Flywheel teeth?
Old May 29, 2003 | 07:04 PM
sivik2nr's Avatar
Default Is this the cover to get access to the Flywheel teeth?
I need to shove something inby the flywheel to lock it in place, so that i can break the crank pulley bolt loose. Is this what everyone is talking about?
I've labeled the where the header and trannie are, and I circled the thing that I think needs to come off.
Another picture
I think it's about 4-5 bolts and that bracket that goes from that plate to the block, which is kinda behind the header. Some one point me in the right direction.
Old May 29, 2003 | 07:07 PM
ZCrex90's Avatar
Default Re: Is this the cover to get access to the Flywheel teeth? (sivik2nr)
its in the same place mine was.....but that was a d16
Old May 29, 2003 | 10:45 PM
carsaregood's Avatar
Default Re: Is this the cover to get access to the Flywheel teeth? (ZCrex90)
i'm pretty damn sure that yes, behind that plate is the flywheel. i think they call it an inspection plate. as far as breaking the crank pulley loose, what i do is the following. i just jack up one side (the driver's side of course) of the car, and leave the passenger side on the ground, wheel on and everything. then put the car in gear, and grab a breaker bar and break the pulley loose. its been working for me very well, just make sure the car is VERY WELL SUPPORTED on jack stands, cuz the torque you are creating can make the car move a bit.
Old May 29, 2003 | 11:01 PM
garagespecial
Guest
Posts: n/a
Default Re: Is this the cover to get access to the Flywheel teeth? (carsaregood)
dust cover and yes thats the part your talking about
SIRIUS VTEC
16
Aug 10, 2010 07:57 PM
1989CivicSi
Dec 17, 2006 06:13 PM
Blueallie
Jan 2, 2005 02:47 PM
altoid
Jun 27, 2003 12:34 AM
Scooby
Jun 28, 2002 01:07 PM
