Squeeking Noise
Old May 29, 2003 | 07:30 PM
red_sir's Avatar
Default Squeeking Noise
I hear a squeeking noise when I slow down. The noise occurs around 2700 rpms in 2nd gear (a little higher in 3rd), and only when it is in gear. If I slow down in neutral there's no noise. It sounds like metal on metal squeeking. It seems to be coming from the front driver side suspension. Could this be caused by a bad upper ball joint? (because I know mine was leaking) That's the only problem I know of in that area. If not, any ideas what it is? Thanks.
Modified by red_sir at 8:49 PM 5/29/2003
islander11
Aug 23, 2006 02:10 PM
2000GSR
Nov 28, 2004 10:01 AM
jeffb16
Oct 6, 2004 05:00 AM
