Compression Test on LS (B18B) ...
Old May 29, 2003 | 01:36 PM
LSiTurbo's Avatar
Default Compression Test on LS (B18B) ...
Just wondering what some of the average #s are when you have done a compression test on your LS motor???????? Please post the mileage and modifications done to your motor. I would prefer stock #s if anyone has them... TiA...
Old May 29, 2003 | 03:00 PM
LSiTurbo's Avatar
Default Re: Compression Test on LS (B18B) ... (LSiTurbo)
Old May 29, 2003 | 03:18 PM
non-VTEC's Avatar
when i had my stock LS engine it had about 180-190psi across all 4 cylinders.
they may range from 170-210psi depending on the milage and condition of the engine.
Old May 29, 2003 | 03:52 PM
Kataku2K3's Avatar
Default Re: Compression Test on LS (non-VTEC)
The B18B standard is 199psi, with the minimum being 135psi and the max variation being 28psi just as with all B series motors... Good Luck
dth0ng69
Sep 22, 2010 08:04 PM
euroborn1
Sep 24, 2008 12:00 PM
Creator
Apr 26, 2007 09:55 AM
V8'suck23
Apr 3, 2003 08:11 AM
shadowdawn
Oct 20, 2002 09:59 AM
