A/C smell...
Old May 29, 2003 | 10:07 AM
zer0zer0 TypeR's Avatar
Default A/C smell...
what causes the vents to give off that nasty wet rag smell? Does the A/C system need to be recharged or is there a simple remedy to fix it?
Old May 29, 2003 | 09:54 PM
99silverbullet's Avatar
Default Re: A/C smell... (zer0zer0 TypeR)
From what I've been told (and what I do) before you turn off your car turn the A/C off but let the fan run for like 30 seconds to get all the freon cooled air out other wise it will sit in the pipes and the moisture can let mold or some kind of bacteria build up causing a nasty *** smell. My A/C doesn't smell at all. hth
Old May 30, 2003 | 04:31 AM
Bontke's Avatar
Default Re: A/C smell... (99silverbullet)
There is a hose under the car near the A/C evaporator that is supposed to let condensation escape. You know when a car is parked with the A/C on during a hot day and it leaves a water puddle, this is the condensation. If the drain hose is clogged you will collect water and it will begin to mold. It could also be leaking inside the car. I have the same smell and haven't yet figured it out. I will have to try that 30 second trick....sounds hopeful.
Old May 30, 2003 | 09:18 AM
turbochic's Avatar
Default Re: A/C smell... (Bontke)
your filter could need replacing also, its located behind the dash near the evaporator
Old May 30, 2003 | 11:53 AM
Default Re: A/C smell... (fmaxturbochic)
hmmm, so next time i park my car, just turn off the a/c switch and it MIGHT cure the problem?
Old May 31, 2003 | 09:36 AM
Bontke's Avatar
fmaxturbochick- What filter are you talking about? Only one I know of is the in line A/C filter and that one won't make a difference.
Old May 31, 2003 | 10:20 AM
9d9GSR's Avatar
After I use my A/C I just unpush the A/C and Ventilation button and just let air from the outside run through the system for about 5 mins. No more smells for me
Old Jun 2, 2003 | 10:57 AM
Denny's Avatar
Default Re: A/C smell... (9d9GSR)
my a/c doesnt smell at all. like 2 minutes before i get to my destination, i just turn off the a/c and let the fans run till i get there. have used my a/c all the time and no smell what so ever.
irideslammed5021
Aug 29, 2006 07:47 AM
decible01
Mar 3, 2005 04:13 PM
WRTEG
Mar 18, 2004 05:51 AM
PTL
Jul 6, 2002 12:55 AM
fang
Jun 10, 2002 05:04 PM
