rounded off head bolt??? AHH
Old May 28, 2003 | 03:49 PM
dfoxengr's Avatar
Default rounded off head bolt??? AHH
working on my friends LS and we're taking off the head, accidentally used a 12 point 14mm on one of the bolts got rounded. we were almost done too, pisses me off. anyways, so we obviously have to get it off without a machine shop, HELP
Old May 28, 2003 | 03:54 PM
non-VTEC's Avatar
Default Re: rounded off head bolt??? AHH (hybridvteceg)
try a 6 point 14mm socket
Old May 28, 2003 | 03:57 PM
Kamin's Avatar
Default Re: rounded off head bolt??? AHH (non-VTEC)
try hammering on a 1mm smaller socket
if that dosent work, vice grips and a rubber mallet.
and make sure you REPLACE the bolt.
Old May 28, 2003 | 03:58 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">try a 6 point 14mm socket</TD></TR></TABLE>
we did ITS ROUND
dfoxengr's Avatar
Default Re: rounded off head bolt??? AHH (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">try hammering on a 1mm smaller socket
and make sure you REPLACE the bolt.</TD></TR></TABLE>
we also tries a 13 12 pt on it. didnt work, its totally round.
cant fit vices in there
Old May 28, 2003 | 04:00 PM
Kamin's Avatar
at a 45 degree angle? all you need is a death grip on that bolt. and anything beloy 90 degrees of an angle.
Old May 28, 2003 | 04:01 PM
dfoxengr's Avatar
its a really tight *** bolt
Kamin's Avatar
lol i know
but a large vice grip and a hammer will take almost ANYTHING off.
Old May 28, 2003 | 04:02 PM
dfoxengr's Avatar
ill see but vices are kindsa big and its a small area
Old May 28, 2003 | 04:03 PM
1bar's Avatar
lol derek go to my thread
https://honda-tech.com/zero...49835
Old May 28, 2003 | 04:06 PM
dfoxengr's Avatar
Default Re: rounded off head bolt??? AHH (1bar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bar &raquo;</TD></TR><TR><TD CLASS="quote">lol derek go to my thread
https://honda-tech.com/zero...49835 </TD></TR></TABLE>
bad thread haha. im helpin us out on both forums
Old May 28, 2003 | 04:21 PM
1bar's Avatar
im about to find out where u can buy me the bolt extractor..
Old May 28, 2003 | 04:27 PM
TREVER's Avatar
heat the head red hot with a torch then hammer a 13mm socket on so the head can take shape. when tha head expands the threads will loose there torque and it will screw out much easier
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bar &raquo;</TD></TR><TR><TD CLASS="quote">im about to find out where u can buy me the bolt extractor.. </TD></TR></TABLE>
yeah right. chris has one im sure
Old May 28, 2003 | 05:09 PM
BigMoose's Avatar
Default Re: rounded off head bolt??? AHH (TREVER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TREVER &raquo;</TD></TR><TR><TD CLASS="quote">heat the head red hot with a torch then hammer a 13mm socket on so the head can take shape. when tha head expands the threads will loose there torque and it will screw out much easier</TD></TR></TABLE>
Trever's tip is a very good one.
Here is the last ditch tip we used to use tractor pullin' 30 years ago. Take about a 4 inch piece of black iron pipe that will fit on top of the nut/stud. Usually 3/8 or 1/2 inch pipe for the big stuff. Have some one hold the pipe down with vice grips. Take your good old arc (stick) welder with 1/8 inch 6010 rod and the electrode holder DC+ polarity. Go in there and burn about 2 or 3 inches of rod onto the nut and against the black iron pipe. You are welding blind with a low slag rod. Let it cool by itself in air. Take vice grips and remove stud/nut/pipe.
Simple as 1 2 3.............. but it takes guts to do it the first time................
Regards,
BigMoose
Old May 28, 2003 | 05:14 PM
dfoxengr's Avatar
Default Re: rounded off head bolt??? AHH (BigMoose)
i am probly gonna weld the socket to the bolt, i thought of that earlier
Old May 28, 2003 | 05:17 PM
mr.beeks's Avatar
I recently saw bolt extractors at sear
has anybody tried them before??
Old May 28, 2003 | 05:46 PM
TREVER's Avatar
They make a rod for that procedure now I think it's called stud plus. Heat is the key.
Old May 28, 2003 | 05:56 PM
speedracer2kjory's Avatar
if u have access to snapon they make a socket that takes off rounded bolts its fairley cheap u just need one for 14mm
Old May 28, 2003 | 06:00 PM
dfoxengr's Avatar
Default Re: rounded off head bolt??? AHH (speedracer2kjory)
yeah i think we have the snaopons at my shop
Old May 28, 2003 | 06:06 PM
Lord Helmet's Avatar
Default Re: rounded off head bolt??? AHH (N T R Z R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N T R Z R &raquo;</TD></TR><TR><TD CLASS="quote">I recently saw bolt extractors at sear
yeah I tried them before, it's pretty helpful because it's shaped just like a regular socket but if you look inside the socket it has left-handed threads to "bite" into the rounded off head bolts. works like a charm for me
Old May 10, 2004 | 10:00 PM
XDEep's Avatar
Default Re: rounded off head bolt??? AHH (sleeperciv)
those craftsman socket extractors wont fit most of the recessed bolts in my LS head. will the snapon one fit?
ive also tried welding several nuts to the bolt heads but they keep breaking off. again, most of them are so recessed, i can only weld to the center, not around the outside. im about to try and chisel those bitches off.
btw whats the quickest way to get the snapon socket w/o ordering online? chase down a truck? make an appointment at your house?
Old May 10, 2004 | 10:07 PM
Dan GSR's Avatar
Default Re: rounded off head bolt??? AHH (XDEep)
try hammering on a 12pt standard size socket
Old May 10, 2004 | 10:15 PM
XDEep's Avatar
Default Re: rounded off head bolt??? AHH (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">try hammering on a 12pt standard size socket</TD></TR></TABLE>
tried 9/16, wont work (9/16" = 0.563" = 14.287mm). i think 1/2 is too small (1/2" = 12.7mm). 14mm = 0.551"..
Old May 11, 2004 | 07:30 AM
Rtype16's Avatar
OKay if you can get the bolt extractor this is a last ditch effort. Drill the head of the bolt off. The head of the bolt holds all the tension once it is off the head will come off and you should be able to unscrew the shank of the bolt by hand.
