Problems with exhaust install *READ*
Iam installing the apexi n1 full cat back exhaust
we just got the stock axle back off and then moved on down to un bolt the stock resantor (sp) where it meets to the cat and we cant get anything to fit on the bolts 13,14,15 wont work ....the bolts are rusted so bad and nothing will get them off???
Please give me some advice
Spray some PB blast and let it set for a while and try vice grips. If the bolts are so bad you might just want to cut/grind them off.
1. Drive car to muffler shop
2. Sit outside, drink beer
3. 30 minutes later, drive car home
They have a lift and torches and bolt cutters and all the new hardware to put it back together.
1-Take the cat off too. Can you run a test pipe in TN?
2-Take the cat off too. Put the whole thing on a bench and bust out a torch, saw, vise grips & a
slammedteg
Mar 15, 2004 04:48 PM
