Fix Horn?
Old May 29, 2003 | 08:58 AM
Grimm's Avatar
Default Fix Horn?
My horn dosen't work what are some good trouble shooting tips and or ways to fix it. Thanks in advance.
Old May 29, 2003 | 10:06 AM
Spoonin's Avatar
Default Re: Fix Horn? (Grimm)
Do you have the stock horn? If not, then put the stock one back in. Then check the fuses.
Old May 29, 2003 | 12:53 PM
Grimm's Avatar
Default Re: Fix Horn? (Spoonin)
yea it's all stock... And i went to locate the fuse but the guide on the fuse door didn't list "Horn" what fuse would it be...
Old May 29, 2003 | 01:14 PM
Raz1983's Avatar
do the simple stuff first: check ground
Old May 29, 2003 | 03:47 PM
APEX CRX's Avatar
What model is it, all honda's have a horn fuse. it may not be just for the horn. it may be incorporated with other circuits
Old May 29, 2003 | 06:51 PM
Spoonin's Avatar
Default Re: Fix Horn? (APEX CRX)
The fuse for the horn may be under the hood.
Old May 29, 2003 | 07:54 PM
OnebadJdmEg6's Avatar
From: being tracked by FAGS Docking PERCENTAGES, GAYFUKS
wouldnt know either here but mines sounds like a jDm fruit truck horn lmao it sounds ugly and low
Old May 30, 2003 | 10:56 AM
Grimm's Avatar
Default Re: Fix Horn? (OnebadJdmEg6)
it's a 96 ex. I haven't had the time to realy investigate anything yet. but thanks I'm going to be spending some time on it tomorow and i'll get back to you all...
Old May 30, 2003 | 11:00 AM
Witty's Avatar
Check ground, check fuse, pull horn and pass 12V through it to see if it works then you know it's not the horn that's the problem.
Old May 31, 2003 | 04:58 PM
Grimm's Avatar
Default Re: Fix Horn? (Witty)
cool thanks witty
hans stoner
Oct 2, 2006 06:11 AM
Tuesdaynightfever
Apr 5, 2005 07:34 PM
EggEX2000
Feb 22, 2004 09:01 PM
NiCkArInO
May 11, 2003 09:13 AM
