Honda MTF - is it worth it?
Old May 28, 2003 | 09:53 PM
petrv's Avatar
Default Honda MTF - is it worth it?
My Prelude 4G has 84.000km (55.000miles) and had geared perfecly. I think there was still original oil in the transmission. Now I have changed the oil for some 10W40 semi-syntetic and the gearing now seems not as smooth as before the change. Is it because of the oil? Should I buy original Honda manual transmission fluid and change it back?
Old May 28, 2003 | 10:08 PM
Kazz's Avatar
Default Re: Honda MTF - is it worth it? (petrv)
i recommend the honda stuff. I used motor oil and gear oil b4. They both made my trans grind. Tried the honda stuff and it doesn't grind anymore.
Old May 28, 2003 | 10:20 PM
acydphryck's Avatar
Default Re: Honda MTF - is it worth it? (JuuKe_EM)
what he said
my Si coupe drives like a champ...71k miles and going strong
Old May 28, 2003 | 10:41 PM
90civichbsi's Avatar
Default Re: Honda MTF - is it worth it? (acydphryck)
anyone ever tried Royal Purple mtf or Redline mtf?
Old May 28, 2003 | 11:04 PM
tilt's Avatar
the semi-synthetic stuff is prob too slippery. If you want to go synthetic try redline mtl, otherwise get some honda mtf.
Old May 28, 2003 | 11:07 PM
tilt's Avatar
Default Re: Honda MTF - is it worth it? (90civichbsi)
Ive tried redline mtl and honda mtf back to back. I'd have to say they are about the same, maybe redline is just a tad smoother when going into gear but it could be just me. both are good products imo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">anyone ever tried Royal Purple mtf or Redline mtf?</TD></TR></TABLE>
Old May 28, 2003 | 11:10 PM
petrv's Avatar
Default Re: Honda MTF - is it worth it? (tilt)
OK, so I'm gonna buy 2 liters of Honda MTF. Before draining the old oil from the transmission, should be the transmission hot to working temperature? When I'm changing engine oil, the engine (and the oil) must be hot.
randerson0248
Jul 28, 2008 08:28 AM
Mashka
Honda S2000
Sep 3, 2007 01:50 PM
16v
Feb 2, 2007 07:15 AM
eag36
Oct 12, 2005 12:50 PM
Quick 200k Mile Motor
Jan 11, 2002 10:59 AM
