failed smog again! wat to do!!!
Old May 29, 2003 | 01:50 PM
kHoA DoGG's Avatar
Default failed smog again! wat to do!!!
Damn it, i cleaned the intake mani and TB w/ cleaner, let the car warm up, pumped 87 octane and still way too much HC's. first run was 176 then 141 now back to 163. the 141 was w/ the autozone stuff.. as for idle, it's at 1000rpm. WHAT DO I DO NOW?!?!
Old May 29, 2003 | 02:27 PM
non-VTEC's Avatar
Default Re: failed smog again! wat to do!!! (sNoOziN' EF8)
what are the limits and final readings for HC CO% and NOx
post those up and i'll tell you what to do......
also make, model or car. engine size and modifications would help too
thanks
Old May 29, 2003 | 02:38 PM
Turbo Powa's Avatar
Default Re: failed smog again! wat to do!!! (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">what are the limits and final readings for HC CO% and NOx
thanks</TD></TR></TABLE>
That info would help
Old May 29, 2003 | 03:58 PM
kHoA DoGG's Avatar
Default Re: failed smog again! wat to do!!! (Panda EK)
it's a 1990 crx w/ a 1989 D16A6 motor. 1.6 L with AEM CAI and cleaned KN filter. Neuspeed 4-2-1 header and wires. 1990 ecu.
HC...C0%....NOx...
Limits: 120....1.00....n/a
Meas: 163...13.2....n/a
idle was at 1041
Old May 29, 2003 | 06:12 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sNoOziN' EF8 &raquo;</TD></TR><TR><TD CLASS="quote">it's a 1990 crx w/ a 1989 D16A6 motor. 1.6 L with AEM CAI and cleaned KN filter. Neuspeed 4-2-1 header and wires. 1990 ecu.
HC...C0%....NOx...
idle was at 1041</TD></TR></TABLE>
first you need to readjust the idle, that's too high of a idle for any honda.
second; what's the mileage on the engine? third got the stock header around? looks like the neuspeed header is not hot enough for the engine to fully burn off the gases.
Old May 29, 2003 | 06:16 PM
Turbo Powa's Avatar
Default Re: failed smog again! wat to do!!! (sleeperciv)
Or maybe you need a new o2 sensor?
Old May 29, 2003 | 06:19 PM
non-VTEC's Avatar
looks like it's EXTEREMLY rich at idle. 13% CO will kill you pretty damn quick.
DO you have a cat converter on that car? by those reading i doubt it. if you do it's doing absolutly nothing. check to see that the o2 sensor is working. and re-adjust your idle speed as well.
also check and set you ignition timing as well.........i would retard the timing to help lower HC and NOx on the driving test.
Old May 29, 2003 | 06:51 PM
kHoA DoGG's Avatar
damn, i do have a cat, all those readings went up recently, i almost passed last time but HC was at 141. how do you check the o2 if it's working? timing is 20degrees which is 2 advance.
Old May 30, 2003 | 01:28 AM
Nice_Dc2r's Avatar
it might be because your motor is old. i just went to the ref and he said and not a lot of motors from 95 and below pass anymore.
Old May 30, 2003 | 06:56 AM
kHoA DoGG's Avatar
Default Re: failed smog again! wat to do!!! (nice_eg)
so wat can i do to make it pass?
Old May 30, 2003 | 07:12 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sNoOziN' EF8 &raquo;</TD></TR><TR><TD CLASS="quote">so wat can i do to make it pass?</TD></TR></TABLE>
The answers were already given
Old May 30, 2003 | 09:23 AM
turbochic's Avatar
Default Re: failed smog again! wat to do!!! (.RJ)
Damn that sux!!!! I know youve been having a hard time with this. I have a stock cat from my 97 if you want it, you can borrow it, i might need it someday, also do you have a fpr? maybe you could lean it out a little bit. that what we had to do to make our car pass, and we had h/cai. aol im me if your interested.
Old May 30, 2003 | 10:19 AM
kHoA DoGG's Avatar
Default Re: failed smog again! wat to do!!! (fmaxturbochic)
the thing w/ a fpr is that it's not street legal
95TegSE
Dec 30, 2006 07:24 AM
twinloop
Dec 28, 2006 12:19 PM
Greasemonkey
Jan 16, 2005 12:00 PM
idumpwitmy12gaugepump
30
Jul 5, 2004 10:55 PM
JDMRob
14
Sep 15, 2003 12:23 AM
