Vtec and the speedo.. simple question..
Old May 30, 2003 | 06:59 PM
92HB_HB's Avatar
Default Vtec and the speedo.. simple question..
Simple question,
does vtec engage even if the speedo is inoperable?? i've got a 93 hatch w/ a 94 gsr and my speedo doesn't work from time to time.. i'm just concerned because i'm gonna get my car tuned eventually on the dyno and don't want to waste my time or money if the tuner can't tune the motor properly because of the vtec engagement issue....
thanks in advance..
Old May 30, 2003 | 07:47 PM
p0rnstar's Avatar
Default Re: Vtec and the speedo.. simple question.. (92HB_HB)
I personally would get that fixed before tuning.
Old May 30, 2003 | 08:04 PM
dfoxengr's Avatar
yes the cluster has nothing to do with it, all signals from the ecu
Old May 30, 2003 | 08:05 PM
Fobtions's Avatar
Default Re: Vtec and the speedo.. simple question.. (hybridvteceg)
check your vss on the tranny
Modified by Fobtions at 9:25 PM 5/30/2003
Old May 30, 2003 | 08:08 PM
dfoxengr's Avatar
Default Re: Vtec and the speedo.. simple question.. (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">if you have a vtec controller you dont need the speedo. other than that you need the speedo to work.</TD></TR></TABLE>
this is not correct.
Old May 31, 2003 | 04:18 PM
92HB_HB's Avatar
but a guy i know used to run his gsr hatch w/ just his autometer tach gauge installed in his hatch w/ his instrument panel and it seemed to work fine for him, so what is the real answer now?? i haven't really gotten a straight answer... much more input would be appreciated b4 i get it tuned...
on a side note, why would the speedo have any input on the tuning aspect, its just there to indicate speed.. if the cluster is at fault, i dont know how it would keep the vtec from functioning properly....
Old May 31, 2003 | 04:21 PM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">yes the cluster has nothing to do with it, all signals from the ecu</TD></TR></TABLE>
badbeast
Jul 16, 2006 09:45 PM
carnifex
Mar 3, 2005 06:51 PM
veilsides2000
Oct 18, 2004 07:38 AM
antireebok
Oct 12, 2003 06:35 AM
HT Chaplain
May 3, 2003 08:23 PM
