Just installed distributor now engine misfires and bogs
Old May 28, 2003 | 07:16 PM
DC2 12's Avatar
Default Just installed distributor now engine misfires and bogs
I just install a 98 gsr obd2 dist. in my b16 obd1 motor. My problem is now that its installed my cars has a hard time starting up. when its starts it runs a bit then it stalls. the motors in the engine bay is shaking irractly. does ne one have a answer or had this problem before. sounds like it is misfiring , the car was running fine until my distributor went out
any help would be appreciated
thanks
Old May 28, 2003 | 07:58 PM
Raz1983's Avatar
Default Re: Just installed distributor now engine misfires and bogs (hoacun)
the answer is: you did a halfass job
did you check the initial timing? did you check spark on all sparkplugs?
Old May 28, 2003 | 10:49 PM
DC2 12's Avatar
NE SUGGETIONS . and yes im getting a spark from the wires
Old May 28, 2003 | 11:45 PM
redegg's Avatar
i believe your problem is you put the wires on wrong and the wrong cylinders are sparking
Old May 28, 2003 | 11:54 PM
B18EG6's Avatar
Default Re: Just installed distributor now engine misfires and bogs (redegg)
Do you know that the distributor is in working condition to begin with? How does the dist rotor look?
heres what my rotor looked like.. my car bogged and misfired as you stated.
edit- Also, here is the dizzy cap and the deposits on the lil metal dudes...
Old May 29, 2003 | 06:48 AM
Raz1983's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoacun &raquo;</TD></TR><TR><TD CLASS="quote">NE SUGGETIONS . and yes im getting a spark from the wires</TD></TR></TABLE>
well then answer my question
did you check base timing?
Old May 29, 2003 | 07:17 AM
Prelude Vtec 23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redegg &raquo;</TD></TR><TR><TD CLASS="quote">i believe your problem is you put the wires on wrong and the wrong cylinders are sparking </TD></TR></TABLE>
That is exactly what the problem sounds like. Check your plug wires and make sure they are connected right on the distributor, they have to go in a certain order.
Old May 29, 2003 | 01:01 PM
Raz1983's Avatar
Default Re: Just installed distributor now engine misfires and bogs (Prelude Vtec 23)
1-3-4-2 i believe
Old May 29, 2003 | 01:10 PM
NOSpeed97's Avatar
Yeah, sounds like your spark plugs are firing at the wrong time. Either the spark plug wires are out of sequence or the distributor is 180 degrees out of phase (?).
Old May 29, 2003 | 01:18 PM
Raz1983's Avatar
Default Re: Just installed distributor now engine misfires and bogs (NOSpeed97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOSpeed97 &raquo;</TD></TR><TR><TD CLASS="quote">Either the spark plug wires are out of sequence or the distributor is 180 degrees out of phase (?).</TD></TR></TABLE>
that has happened before with my friends too. dist 180 deg. off.
thats why im saying check timing, but the guy doesnt want to listen so oh well.
integ_lude
10
Oct 1, 2007 04:02 AM
girlieracerk
Dec 18, 2003 10:12 PM
24seven
Aug 27, 2002 02:23 PM
