Toda valve springs/retainers + Ferrea valves work for skunk stage 2???
I currently have a set of toda spec C with toda valve springs and retainers and cam gears with Ferrea valves. I was wondering if it would be alright to run the skunk2 stage 2 cams with the toda stuff and Ferrea valves??? or should I replace the springs/retainers to skunk2 as well??
because I don't want to loose any money selling the toda stuff and rebuying skunk2 stuff.
I heard that the toda valve springs might be too stiff for the skunk2 stage 2's? maybe I'm wrong and that only goes with stock itr cams.
I did my search but could not find anything, thanks a lot for reading this
kevin
kevin
Re: Toda valve springs/retainers + Ferrea valves work for skunk stage 2??? (BoostinDC2)
are you sure the springs won't be too stiff for the stage 2's? what about the retainers? any differences between toda and skunk??
1 Post
Re: Toda valve springs/retainers + Ferrea valves work for skunk stage 2??? (sir2k)
springs are fine and a retainer is a retainer. as long as you have upgraded valve train you will be fine with any cam upgrade.
todasprings are some of the best springs on the market.
not too stiff and handle lots of lift. much more than stage 2skunks.
you will be fine.
you will be fine.
gakkuken
18
12-14-2004 10:46 PM
Renegade
11-01-2004 08:19 AM
