does displacement change if thicker/thinner headgasket is changed
Old May 30, 2003 | 09:23 AM
Rob Dizzle's Avatar
Default does displacement change if thicker/thinner headgasket is changed
I am trying to figure out if displacement would change if someone either put a thinner headgasket or thinner headgasket. Same thing would apply if they milled the head.
The piston is still travelling the same amount, but there could be more or less area under the valves.
anyone know?
Old May 30, 2003 | 09:30 AM
turbochic's Avatar
Default Re: does displacement change if thicker/thinner headgasket is changed (Bob-DC2)
when i figured my displacement out on my car with the 2mm head gasket it changed but only a tiny amt
example before: 1590.5858
example after gasket: 1590.6099
Old May 30, 2003 | 10:00 AM
JimBlake's Avatar
Default Re: does displacement change if thicker/thinner headgasket is changed (fmaxturbochic)
NO
Displacement is defined as the volume swept by the piston between TDC & BDC. It's not even corrected for the non-flatness of the piston or the head. It's just like this:
disp = pi/4 * bore^2 * stroke
Compression ratio is what changes with your headgasket.
Old May 30, 2003 | 09:57 PM
Rob Dizzle's Avatar
Default Re: does displacement change if thicker/thinner headgasket is changed (JimBlake)
okay, so displacement is changed. at least in terms of how displacement is defined.
but, the volume in the cylinder changes.
would this effect power in any way?
Old May 30, 2003 | 10:09 PM
MikeMAN's Avatar
no.
the displacement is the minimum volume of the combustion chamber subtracted from the maximum volume of the combustion chamber. sure your max volume has gone up, but so has your minimum
very interesting to think about..i drew it out and it makes perfect sense
example:
<U>No Headgasket:</U>
Max Volume is 10
Minimum is 5
Difference = 5
<U>1mm Headgasket *hypothetical:</U>
Max Volume has increased to 11
But minimum has ALSO increased to 6
Difference = 5
hope that helps
mike
Old May 30, 2003 | 10:50 PM
simple4012's Avatar
New User
Default Re: does displacement change if thicker/thinner headgasket is changed (MikeMAN)
bore and stroke are the only things that determine displacement
Old May 30, 2003 | 11:03 PM
MikeMAN's Avatar
Default Re: does displacement change if thicker/thinner headgasket is changed (simple4012)
thats what i was trying to explain in a round about way
that the area the piston is displacing is still the same...
i apologize if it was confusing! :D
hehe,
mike
Old May 30, 2003 | 11:31 PM
WundedSaint's Avatar
Your compression ratio can be changed with the headgasket though.
beyondstock
Mar 15, 2009 06:38 PM
WorrGame13
Mar 30, 2007 03:35 PM
OEMcivic
Jan 5, 2005 08:20 AM
99b18
13
Mar 9, 2004 03:56 PM
Evs-One
Mar 3, 2003 01:09 AM
