Bore block to 84mm - What about the HEAD ? ? ?
Old May 29, 2003 | 10:36 PM
rodimus's Avatar
Default Bore block to 84mm - What about the HEAD ? ? ?
i'm getting a B16 head done up by alaniz to put on my gsr block.
i'm thinking of resleeving to 84 mm's...i think alaniz also offers a service
to open up the chambers or something to 84 mm?
do i really need to do this to my head if i resleeve?
what are the advantages?
and
will the advantages be great?
Old May 29, 2003 | 10:57 PM
sgT's Avatar
sgT
Default Re: Bore block to 84mm - What about the HEAD ? ? ? (EVOL)
if done right you can see gains.
not totally necessary though.
Old May 30, 2003 | 01:18 AM
FFormula1's Avatar
One advantage would be that you are able to de-shroud the valves more with the increased bore dimension which will aid in mixture homogeny and increase flow.
Old May 30, 2003 | 02:53 AM
Westrock2000's Avatar
Default Re: Bore block to 84mm - What about the HEAD ? ? ? (Muffin')
Also by keeping the same size combustion chamber, but increasing the cylinder volume you are increasing the compression ratio of the engine....the b16 has one of the smallest combustion chambers...so you can open it up a bit. I will help the quench fact , and can make the compression ratio a little lower/safer.
Old May 30, 2003 | 04:35 AM
BROOD's Avatar
Default Re: Bore block to 84mm - What about the HEAD ? ? ? (Westrock2000)
The GSR cylinder head has less cc volume than the B16A and ITR cylinder heads.
Alaniz will upen up your combustion chambers to match the bores but that option is only available on the higher combination packages. He will not do this if your buying the street master package. FYI
But I will say that Alaniz does some excellent cylinder head work
Modified by SLPR at 6:11 AM 5/30/2003
Old May 30, 2003 | 06:00 AM
rodimus's Avatar
Default Re: Bore block to 84mm - What about the HEAD ? ? ? (SLPR)
thanks guys
honda-tech still is dope besides all the drama lol
i think i will end up just not doing it...
head has competition work done by alaniz
Old May 30, 2003 | 08:06 AM
BluntMan's Avatar
if you dont match the head to the bore you may create hot spots.
hot spots = detonation
Old May 30, 2003 | 06:58 PM
Ruby Civic's Avatar
Default Re: Bore block to 84mm - What about the HEAD ? ? ? (BluntMan)
as has been said before, and quoting tom fujita of portflow fame: you may safely leave them alone = not an issue
Old Aug 4, 2006 | 11:43 PM
Johnny_9's Avatar
Default Re: Bore block to 84mm - What about the HEAD ? ? ? (Ruby Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruby Civic &raquo;</TD></TR><TR><TD CLASS="quote">as has been said before, and quoting tom fujita of portflow fame: you may safely leave them alone = not an issue</TD></TR></TABLE>
Some guru say u need to "spot face" - stepped squish area is an invitation to detonate.
Old Aug 5, 2006 | 10:10 AM
rodimus's Avatar
Default Re: Bore block to 84mm - What about the HEAD ? ? ? (Johnny_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny_9 &raquo;</TD></TR><TR><TD CLASS="quote">
Some guru say u need to "spot face" - stepped squish area is an invitation to detonate.</TD></TR></TABLE>
wow, you resurrected a 3 year old thread...lol
tobe1424
45
Aug 19, 2006 05:01 PM
TGG170
Jun 21, 2005 03:30 PM
Drag-On23
Aug 29, 2003 04:04 PM
94obd1vtec
Jun 19, 2003 03:17 PM
