HELP, throttle body still sticking......
Old May 29, 2003 | 06:15 PM
turbo Si's Avatar
Default HELP, throttle body still sticking......
The piece of **** is still sticking. Here is what I noticed, yesterday I sprayed some throttle body cleaner and it worked great for about 10 minutes of driving. Today I took the throttle body off, and completely sprayed and wiped it down, and installed a new throttle cable. Like yesterday, it did good for 10 minutes of driving and it started to stick.
What the hell could this be?
Old May 29, 2003 | 06:50 PM
BluntMan's Avatar
Default Re: HELP, throttle body still sticking...... (turbo Si)
your butterfly valve might not be clearing the throttle body. if it looks like its touching the throttle body anywhere file it down a little bit. or rig another return spring on the throttle.
Old May 30, 2003 | 04:05 AM
turbo Si's Avatar
Default Re: HELP, throttle body still sticking...... (BluntMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BluntMan &raquo;</TD></TR><TR><TD CLASS="quote">your butterfly valve might not be clearing the throttle body. if it looks like its touching the throttle body anywhere file it down a little bit. or rig another return spring on the throttle.</TD></TR></TABLE>
Another return spring, or replace the spring on the outside?
But how could the plate begin to rub? It's never been messed with. This is such a headach!
FATninja19
Jun 26, 2006 10:51 PM
2kEM1ebp
Aug 20, 2005 03:28 AM
