Adj. Cam gears
Old May 28, 2003 | 03:49 PM
XLR8 GS-R's Avatar
Default Adj. Cam gears
I know skunk makes the best. But why? What is the point of adj. cam gears? I know you can extract a few hp from tuning them to ur setup on the dyno- but if you use them in stock setting/configuration- will you still gain any hp? They are sure a hell of alot lighter then stock.
Old May 28, 2003 | 04:40 PM
dfoxengr's Avatar
Default Re: Adj. Cam gears (XLR8 GS-R)
its all about changing when the valves open and close. timing. it can help on stock motors, but no need to wate money on a dyno, just advance or retard what is known to have gained your motor some numbers. and youll be fine
Old May 28, 2003 | 04:52 PM
XLR8 GS-R's Avatar
Default Re: Adj. Cam gears (hybridvteceg)
Can you go a little more into this self adjusting? Thanks bud
Old May 28, 2003 | 05:01 PM
dfoxengr's Avatar
not to be a dick, but i dont feel like it, you can search. and BTW skunk2s are the best.
Freshdot
May 17, 2011 05:32 PM
goose21
Jan 6, 2004 12:45 PM
b00stedbyFastrax
May 22, 2003 08:52 AM
insnimprtguy
Jul 17, 2002 02:11 PM
spankaveli
Jul 31, 2001 03:18 PM
