O2 sensor wires
Old May 29, 2003 | 10:43 AM
pregunta's Avatar
Default O2 sensor wires
I was changing my exhaust from cat back and I pulled wires out of the plug for the o2 sensor by mistake. Can anyone help me figure out what order to put them back in? It is a 95 GSR. Four wires 2Xblack 1xwhite 1xgreen.
Old May 29, 2003 | 06:53 PM
sivik2nr's Avatar
Default Re: O2 sensor wires (pregunta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pregunta &raquo;</TD></TR><TR><TD CLASS="quote">I was changing my exhaust from cat back and I pulled wires out of the plug for the o2 sensor by mistake. Can anyone help me figure out what order to put them back in? It is a 95 GSR. Four wires 2Xblack 1xwhite 1xgreen. </TD></TR></TABLE>
Looking at the back of the plug ( that comes from the O2 sensor it self ) the black wires are bottom left and bottom right. The green wire is the upper left and the white wire is the upper right.
Here's a picture:
The other side of the plug is the mirrored image of the other side. Black wires are the bottom left and bottom right, but the green wire is the upper right and the white is upper left, looking at the BACK of that plug.
Old May 30, 2003 | 05:15 AM
pregunta's Avatar
Default Re: O2 sensor wires (sivik2nr)
You the man. Thank you very much
-Pregunta
Old May 30, 2003 | 05:38 AM
HATCHFREEK's Avatar
where does the 02 sensor plug into, in the engine(what location)
Old May 30, 2003 | 09:14 AM
10K2HVN's Avatar
Default Re: O2 sensor wires (HATCHFREEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHFREEK &raquo;</TD></TR><TR><TD CLASS="quote">where does the 02 sensor plug into, in the engine(what location)</TD></TR></TABLE>
wow.
edit:
OB1 into the end of header or beginning of cat
OB2 into end of header and back of cat.
Modified by 10K2HVN at 12:10 PM 5/30/2003
Old May 30, 2003 | 09:35 AM
pregunta's Avatar
Default Re: O2 sensor wires (10K2HVN)
On my car (OBDI) it is at the begining of the cat. On OBDII. It is on the header and I think after the before the cat.
fragmare
Sep 4, 2013 02:21 PM
EKjdmCTR
May 5, 2007 11:22 PM
Frozen E
Apr 26, 2006 12:14 PM
SMC Integra
May 20, 2003 06:31 PM
Farnsrocket
Dec 12, 2001 12:37 AM
