Some weird questions
Old May 28, 2003 | 08:15 AM
CW_97_ITR's Avatar
Default Some weird questions
The first one, anyone know a general volume of a tire on a 15 inch wheel? I know it depends on tire size and the shape of the rim on the inside, but just a general number would be awesome.
The second, to figuer out the loading a-arm would see during normal driving would it just be the force of the spring can provide for general terms? I think the only way an a-arm would see higher loads would be if the spring was bottomed out.
Thanks for your time.
Old May 28, 2003 | 01:22 PM
JimBlake's Avatar
Default Re: Some weird questions (CW_97_ITR)
volume of torus = 2 * pi^2 * R * r^2
195/55 R 15
take r = average tire section radius
= 7.5cm
take R = radius to centerline of 'tube'
= 24.3cm
V = 27000 cm^3 or about 1650 in^3
The dynamic part of the load on the a-arm is probably way bigger than you think. The damping force from the shock might be bigger than the spring force for normal motion of the suspension. Then you have to add cornering forces.
DialedLife
Suspension & Brakes
21
May 21, 2012 02:12 PM
Records
Feb 29, 2012 05:30 PM
vinuneuro
Jan 19, 2010 07:13 PM
Cory Matthews
Apr 13, 2005 01:53 PM
turbotime
17
Jul 9, 2004 11:50 PM
