Highest Compression with 91 octane
Old May 29, 2003 | 11:08 AM
Twenty36_1's Avatar
Default Highest Compression with 91 octane
I searched highest compression Pump gas and I could only find info on 93 octane. Cali really sucks and we only get 91 octane. So my question is what is the highest compression I could run with Endyns rollerwave pistons (81.5mm bore) in an LS/vtec set-up with an ITR head and stock sleeves?
Old May 29, 2003 | 11:53 AM
TuRbEeZy's Avatar
Default Re: Highest Compression with 91 octane (Twenty36_1)
I would say the highest compression you can run on stock sleeves is about 11.5:1-12:1, but you need to have a good engine management system such as hondata. Also there is less room for error, so the motor needs to be tuned with precision. You really dont need anything more than that for a street car, just get a good set of cams and you should make some nice numbers. What does ur whole set up consist of??
Old May 29, 2003 | 11:56 AM
alex_b's Avatar
Default Re: Highest Compression with 91 octane (TuRbEeZy)
i wouldnt go over 12:1 just to play on the safe side.
Old May 29, 2003 | 01:18 PM
Twenty36_1's Avatar
When Completed (still researching so I only by stuff once)
2001 ITR Head (2001 ITR cams and valve train)
ITR Intake Manifold
Ericks Racing 66-68mm TB (or Cheaper Alternative, Any suggestions?)
I/E
JDM ITR headers (W/heatshield for sleeper look)
GSR Tranny w/JDM final Drive
Exedy Clutch
Toda Flywheel
LSD (Later, when money permits
310cc Injectors
B18A block
Rollerwave pistons
Probe Industries Rods
Sully90SiPrelude
Nov 28, 2006 10:42 AM
jikespingleton
Nov 21, 2006 09:02 AM
LvN
Mar 17, 2006 09:38 AM
spooncivic1
Dec 20, 2004 06:44 PM
Rocket
May 5, 2002 12:32 PM
