how to check TDC
Old May 28, 2003 | 03:32 PM
ENeRg3Tic's Avatar
Default how to check TDC
my crank pulley key fell out and i am waiting on honda to get some in
i kno my cams are off....
how can i check if it is TDC to adjust the cams
do i have to set the key in the crank pulley first
Old May 28, 2003 | 04:06 PM
Kataku2K3's Avatar
Default Re: how to check TDC (ENeRg3Tic)
I just posted this yesterday and hopefully it should help you so here it is again... As for telling if the cam sprockets are at top dead, make sure the two arrows are pointing up, then align the two ticks... For the IN cam it will be at nine-o-clock and for the EX at three-o-clock... It's not hard at all...
Old May 28, 2003 | 04:20 PM
jdircksen's Avatar
Default Re: how to check TDC (Kataku2K3)
And just a tip, you may have to try getting it right a couple times. When changed my timing belt, I would align the crank, the tighten the tensioner and TDC would change.
Old May 28, 2003 | 04:32 PM
dfoxengr's Avatar
Default Re: how to check TDC (jdircksen)
also theres a hole in each cam near the gear. put something in there and thats TDC
Old May 28, 2003 | 05:13 PM
Kataku2K3's Avatar
Default Re: how to check TDC (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">also theres a hole in each cam near the gear. put something in there and thats TDC</TD></TR></TABLE>
Yup, forgot about that cuz i normally don't set cams to top dead with them (for me, just for torquing down the sprockets) On a VTEC head the holes will be in the cam rails... on a nonVTEC such as the B18A/B or B20B/Z they'll be located in the timing belt side cam cams... Latez
Old May 28, 2003 | 05:50 PM
ENeRg3Tic's Avatar
koo thanks for the info
goota
Aug 22, 2009 07:38 AM
blue_hatch
Sep 7, 2007 10:38 AM
MugenHonda
Mar 8, 2005 12:41 PM
spyderracing
14
Sep 26, 2004 09:10 AM
