Air intake causing car to run lean?
Old Aug 2, 2001 | 06:52 PM
gns30's Avatar
New User
Default Air intake causing car to run lean?
Well here it goes. I have had an aftermarket intake on my 98 Accord for a just replaced my plugs. Looking at them they looked as if the motor was running lean. Can the intake make that possible? This is the only mod done to the motor.
I know that the computer runs on a preprogramed chart after a certain load or throttle opening and was wondering if this intake makes enough of a diff to make the motor run lean, same fuel amount just more air now! If it is the problem what could fix it, a FPR? Any ideas!? Thanks!
Old Aug 2, 2001 | 08:57 PM
t's Avatar
t
Default Re: Air intake causing car to run lean? (gns30)
it could make it run slightly lean at some rpms. A fuel pressure regulator would help.
Old Aug 3, 2001 | 07:48 AM
redline504's Avatar
New User
Make sure to reset the ECU after installing any aftermarket performance items.
Run the car for 5 minutes. Shut down and remove the ECU fuse for another 5 minutes. Then replace the fuse and run the car another 5 minutes. Then shut off.
Old Aug 3, 2001 | 11:14 AM
976's Avatar
976
New User
Default Re: Air intake causing car to run lean? (redline504)
If you install intake, headers, exhaust, then I would worry about engine running lean. Just intake doesn't effect it too much. B&M make a good FPR; command flow.
Old Aug 8, 2001 | 03:13 AM
IgniteTeg's Avatar
Default Re: Air intake causing car to run lean? (prsi)
How do you know if your runnin lean????? Any symptoms?
Old Aug 8, 2001 | 09:58 AM
976's Avatar
976
New User
Default Re: Air intake causing car to run lean? (IgniteTeg)
The engine bogs a little, and you can tell from white corrsion on spark plugs.
Old Aug 8, 2001 | 03:28 PM
archmage's Avatar
Does running lean mean that the ratio of air to fuel is off such that the air component is a bit too high?
If so, is this why turbo people generally have bigger injectors, to deliver more fuel to make the A/F ratio optimal?
and then I assume "rich" = too much fuel eh?
Old Aug 8, 2001 | 05:21 PM
fixhondas's Avatar
I don't know what the hell this is going to do but waste 10 minutes
Old Aug 8, 2001 | 09:02 PM
IgniteTeg's Avatar
Default Re: Air intake causing car to run lean? (fixhondas)
this is suppose to reset your ecu to let it relearn the new air/fuel that you installed performance aftermarket parts.
Old Aug 9, 2001 | 07:16 PM
fixhondas's Avatar
why would you let it relearn and then wipe it out again?- that's what I was getting at. The ecu will relearn even if you don't clear it.
Old Aug 9, 2001 | 08:21 PM
IgniteTeg's Avatar
yes thats true but it will take it away to relearn instead of doin it manually.
Old Aug 10, 2001 | 06:34 AM
gns30's Avatar
New User
I was replacing my plugs the other day and noticed that they had a slight yellow tint on them. Also, plug # two had small metal frags on the insulator tip, from what I hear that equals detonation!? The only thing I figured was that the air intake changed the A/F ratio and caused the motor to run lean and hotter than normal. Also using 87 octane probably didn't help. I never reset the ECU until I changed the plugs, I haven't checked them since then. Any suggestions?
Old Aug 19, 2001 | 11:59 PM
ben_vtec's Avatar
New User
resetting the ecu definatly works. i fitted an induction kit an de-cat pipe to my civic twincam vtec and the car was running like ****. the vtec didnt come on til late (if it came on at all) and the check engine light was coming on. it didnt get better at all for 2 weeks(in fact it seemed to be getting worse) until someone advised me to reset my ecu. guess what, running like a dream and faster than ever.
mark31kiss
10
Feb 8, 2021 02:10 PM
immajackuup
Honda Civic (2006 - 2015)
12
Sep 6, 2013 10:21 AM
Eresuncabron
18
Oct 5, 2004 03:02 PM
iampeetor
Jul 3, 2004 07:37 AM
Sracer125
Nov 12, 2001 06:46 PM
