Balancing Shaft Questions
Old Jul 17, 2001 | 10:03 PM
H22CIVIC's Avatar
New User
Default Balancing Shaft Questions
What would happen if I removed these shafts? I've been told I can as long as I balance the crank and cap the holes in the block. Is this true? What exactly do these balancing shafts do?
Old Jul 18, 2001 | 03:18 AM
CardDealer's Avatar
Banned
Default Re: Balancing Shaft Questions (H22CIVIC)
Modified by CardDealer at 4:15 AM 11/16/2006
Old Jul 18, 2001 | 05:10 AM
92Si's Avatar
New User
Default Re: Balancing Shaft Questions (schlit)
I know DSM people remove the balancer shafts, maybe someone cam fabricate a sprocket to go there instead?
Old Jul 18, 2001 | 11:59 AM
H22CIVIC's Avatar
New User
The balancing shafts run on there own belt. The timing belt has nothing to do with the balancing shafts. Does anyone else have any input on this topic?
Old Jul 18, 2001 | 01:22 PM
sysopt's Avatar
New User
I wouldn't recommend doing this. The shafts are critical in larger 4 cyl. like your h22. Without them you would have lots of second order vibration potentially ruining your crank and bearing. Not to mention it would probably be a real pain in the bottom to remove them IF it were possible. Honda put them there for a reason, just leave em there. I doubt you would get any usable horsepower from it, and even if you did, it wouldn't be worth all the trade offs.
[Modified by sysopt, 4:27 AM 7/19/2001]
Old Jul 18, 2001 | 01:25 PM
H22CIVIC's Avatar
New User
Default Re: Balancing Shaft Questions (sysopt)
I was just curious cuz I know the DSM guys do this and they claim they gain 8-10 hp on a stock setup!
Old Jul 18, 2001 | 04:04 PM
HXMan's Avatar
My friend just removed his balance shafts from his DSM....the car does seem stronger now in the high rpms.....but vibration is an issue. I don't think it is bad enough to be detrimental to the motor but it is noticible.
I don't think the time, effort, and possible bad effects are worth the removal of the balance shafts.
Old Jul 18, 2001 | 08:07 PM
H22CIVIC's Avatar
New User
Default Re: Balancing Shaft Questions (HXMan)
Thanks for the info guys!!!
turboITR#704
Sep 23, 2015 06:45 PM
mister2racer
Nov 29, 2010 11:11 AM
soon2bdropped
Apr 16, 2007 12:01 AM
BB6racer
Sep 5, 2005 07:33 AM
valve79
Jan 4, 2005 07:37 PM
